FE-30 Hatch Poor Fit
  • teddyboy
    • Jan 2010
    • 518
    Does anyone have any idea where a new Epoxy hatch can be pruchased for a FE-30 Insane Hydro. Mine is new but the fit is very poor with the ends curled up. I have read of some heating procedures, but they are not a permanent fix.
    Thanks for any inputs.
    Ted H. Wachter
    West Florida Model Boat Club
    East Texas RC Boaters
  • electric
    • 1744
    Common issue with those FE-30's. I have one to. Maybe we can speak with the person who is making those cowl's for the Gieco boats...
    I ended sanding a bit off the inside part of the cowl to lower it so the "flair" is not as much of an issue, but it still does require a fair amount of tape to hold it down.
    The boat is still my favorite in terms of speed and handling...
    • teddyboy
      • Jan 2010
      • 518
      FE-30 Hatch
      I will drop him a line and if I get any good news I will share the information with all.
      Thanks for the response.
      Ted H. Wachter
      • teddyboy
        • Jan 2010
        • 518
        FE-30 Hatch
        Gentleman and FE-30 Owners,
        I have sent Scott (fabricates epoxy hatch for Miss Gieco) a PM to see if he would be interested in production of FE-30 hatch made of Epoxy Resin. If anyone else is interested, please serve notice, where as we can make it worth Scotts while for the effort.
        Thank you all
        Ted Wachter East Texas RC Boaters President.
        Ted H. Wachter
        • Darin Jordan
          • 8332
          Jeff at Insane will make you an epoxy hatch. Contact him and get the details. Not that exensive and fits much better.
          Darin E. Jordan - Renton, WA
          • teddyboy
            • Jan 2010
            • 518
            FE-30 Hatch
            Darin, thanks, I will consider that after giving one or our OSE members a chance.
            Thanks again.
            I haven't contacted Jeff as of yet, so I will have to give him a chance to correct this issue. It seems like Jeff should make it good on warentee issue.
            Ted
            Ted H. Wachter
            • electric
              • 1744
              I actually just sent him an email asking about a replacement hatch. In my case (I have had the boat for a long time) I am ok with paying for a new one. The big question is did he figure out what was causing that to happen and was he able to correct it? Mine was warped from the start, but I had purchased this boat right about the time he had just started to make them.
              • teddyboy
                • Jan 2010
                • 518
                FE-30 Hatch
                I have sent Jeff at Insane and Email and we will see what comes out of it. Mine is a new boat (undrilled) and I have been stalled in building due to the cowl condition. I want to have a cowl that fits and will tape down good for water proofing. Thanks will keep all informed as this unfolds.
                Ted H. Wachter
                • johnf
                  • Dec 2009
                  • 1078
                  Ted,
                  Is this the FE30 I sold you? I hope you don't think I was trying to hide anything, as the hull was exactly as it came to me. I just figured everyone knew about the fitment, since it seems to be mentioned in most of the FE30 threads, including the introduction thread by Tony. I was just going to have some sort of hatch lock / screw in every corner of the hatch.
                  Hopefully you can get it straight and build that bad boy. I'd love to see a vid or at least pics of it done.
                  Catching Air!
                  • Chilli
                    • 3067
                    I recieved a new FE30 about two months ago and knock on wood, the hatch is fine. Hopefully Jeff has resolved what ever the problem was.
                    Mike Chirillo
                    www.capitolrcmodelboats.com
                    • tiqueman
                      • Jul 2009
                      • 5669
                      Ted, I replied to your PM. Let me know if I can be of any assistance.
                      -Scott
                      • knpc
                        • 566
                        Mine was a bit curled up as well, but it was an easy fix. I put tabs on the bottom side of the front of the cowel that slide under the deck of the hull. Then for the back I used two thumb screws to hold it down, makes for a good fit and holds it flush. I would have done this whether the cowl fit well or not as I don't trust tape alone to hold the hatch on for higher speed boats.
                        Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
                        • properchopper
                          rcgoatbuild@snotmail.com
                          • 6958
                          I will look into this and get back to you
                          • detox
                            • 2310
                            Shrinking of the Gel coat or two part paint will cause curling on thin hatches. The longer it cures the more shrinkage or curling you will get until it has cured fully. So if you purchased a new hatch then painted it using two part paint it may curl up again. I would use regular Krylon paint to prevent shrinkage.
                            • teddyboy
                              • Jan 2010
                              • 518
                              FE-30 Hatch
                              Thanks to all of the OSE members as usual. I have a few different paths to cross, but would like to lean toward a new Epoxy cowl.
                              Thanks again
                              Ted H. Wachter
