DF26 build questions.
  • wparsons
    • 461
    I'm still looking for the hull, but have a couple questions as I order bits and pieces. It'll be powered by an SV27 motor/esc and 4s5000mah.
    Is there much benefit to running rails in it, or is it better to just put down a layer of c/f on the whole floor and running a typical mount?
    I was thinking of buying a mount like this:
    http://www.offshoreelectrics.com/pro...prod=ose-80200
    or:
    http://www.offshoreelectrics.com/pro...prod=ose-80230
    and instead of running the side plates, bolting the aluminum parts directly to the rails. Rail spacing would be dictated by the width of the mount parts.
    I know rails stiffen the hull, but is it overkill for a 26" hull on SV27 power?
    Having the rails also gives me a nice place to mount a shelf to mount the servo, RX and ESC.
    If I do build rails, how thick is adequate? 1/8" lite ply feels stiff enough to me, but I could be out to lunch?
    Light travels faster than sound, so people may appear to be bright until you hear them speak.
  • Rumdog
    • 6667
    You won't need rails in the 26. A little extra glass or CF will do just fine.
    • Diegoboy
      • Mar 2007
      • 7444
      Thread moved
      • wparsons
        • 461
        ^^ Thanks, I forgot about this section!
        Rumdog, will rails have any negative side effects? I think I like the layout I'm picturing with narrow rails and a shelf to mount all the electronics.
