df 29 on 4s2p?
  • driftah
    • 759
    df 29 on 4s2p?
    I am running 2x2s lipos now and my boat is good but was considering going to a dual 4s pack setup.I want to know if I will get more speed as i am effectively doubling the batt. weight and runtimes will go up too correct? Or should I just invest in some more batteries that are 2s with a higher c rating and call it a day? its in a df29 with a 7xl and t180 esc on a x445 prop
  • steveo
    • 1595
    what c rating do ypu have now
    • driftah
      • 759
      50c 54oomah
      • driftah
        • 759
        and will the turnigy 180amp esc handle 4s2p current with 5000mah 40c setups???
        • siberianhusky
          • Dec 2009
          • 2206
          It's not going to draw any more amps, the extra runtime might cause heat buildup issues. All you are doing is adding capacity, not voltage.
          • driftah
            • 759
            so then maybe just grab some more 2s packs?
            • Make-a-Wake
              FE Rules!
              • 6057
              The 50c 5400 packs are whoppers to start with....................you must have some pretty good run time. 2p will not get you any more speed..........the batts are more than up to the task of providing the amps the motor wants.
              • ksm2001
                • 397
                Driftah, by going with a 2p setup using the x445 and a 7xl you'll get more run time but with the extra weight you will loose some speed and create more heat and run higher amps. I run mine on 4s1p with a 8xl using a m445 and a 200 amp esc and I'm spiking at 140 amps. I'd stay with the 4s1p setup to be safe.
                Ken
                DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
