No spark calculator
  • scoota
    FE DOWN UNDER
    • Dec 2008
    • 439
    No spark calculator
    Heres a link i found with some good info http://scriptasylum.com/rc_speed/nospark.html
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
  • gultch
    • Jan 2011
    • 66
    hi great link im just a little confused when they say total esc capacitance in uf do u add all youre capacitors together for example my t180 upgraded has 6 1000 uf caps so do i enter 6000 uf or 1000 thanks in advance
    genesis leopard 4074 2000kv t180/ hk vanquish cc1717 hydra 240/ fibreglass carbon hydro 38" build in progress
    • drwayne
      • 3012
      T180 caps are in parallel.. so add them together.
      If series, the calc is c c1xc2xc3xc4/[c1+c2+c3+c4]
      • gultch
        • Jan 2011
        • 66
        so how can u tell wether youre caps are in series or parallel for example a hydra 240's caps are ? and a phoenix ice 160hv is thanks
        • m4a1usr
          Fast Electric Addict
          • 2036
          You can safely assume that the caps on all speedos are all in parallel. The reason is simple. Caps wired in parallel are additive, the final capacitance is the total sum of each capacitors value (like the example Wayne posted). Wired in series the capacitive value is subtracted, meaning the final value will be less then each components stated value. We typically need more cap value in our speedos. Not less.
          John
          Change is the one Constant
          • m4a1usr
            • 2036
            Guy's dont forget if you are building a spark arrestor for a Castle speedo use a 1 ohm resistor. Dont go by any calculator to determine the value. Joe Ford has a post somewhere here on OSE with his recommnedation. Something to do with the battery cutoff setting.
            John
            • gultch
              • Jan 2011
              • 66
              thanks john
