Shockwave36 Conversion build
  • saleens7
    • 1130
    Im in the middle of a conversion using the SW36 hull (the old nitro in it just never ran right) and so far i have the motor installed, the esc is ready to be put in, and im only a few bucks away from buying the batt's.
    it uses a Quantam 36x70 BL motor and a welgard 100amp esc. It will be powered by 24 IB3600 cells.
    some pics:
  • saleens7
    • 1130
    • saleens7
      • 1130
      • saleens7
        • 1130
        • Mich. Maniac
          • 1456
          looking good, will your esc be water cooled?
          • saleens7
            • 1130
            yes, im going to take off the covering and glue on some cooling plates with some thermal epoxy..
            • Steven Vaccaro
              Administrator
              • 8932
              There have been some people playing with that motor on other forums. Their experience hasnt been good. Start with a very small prop with that motor.
              Take baby steps.
              Steven Vaccaro
              • saleens7
                • 1130
                im only using a 40mm prop right now...it looks pretty small....
                • Mich. Maniac
                  • 1456
                  the reason i ask about esc is I want something about 100 amp for my motors but want it water cooled, so far only thing i like is bk9920
                  • saleens7
                    • 1130
                    should i replace the current motor with a feigao 14XL? ive been hearing bad things about it, not just from Steven, but on a bunch of other forums..
                    also, ive been told that i should grind out a small flat spot in the shaft to give the coupler's set screws a better grip, but ive been having trouble....the shaft it alomost indestrictable..ive been trying to grind out a flat spot with a file for hours and have been pressing on the shaft so hard when i do im afraid ill bend it...and so far, the most ive done is scratched it...the coupler has two set screws at around 120* from eachother, would that be enough to hold on to the shaft or will it just spin? i know people who dont put a flat spot on and the coupler never comes loose on em and they use high power setups, where others couplers wont even stay on the shaft longer than 2 second nless they ave a flat spot...im kind cautios about going at it with a dremel too.....is there another way to cut a flat spot in the shaft
                    • DuckOfDeth
                      • 63
                      Saleens,
                      What type of file are you using? Try a mill (bastard) file. Designed to be used in one direction only. We use them to sharpen concrete boring bits, and they should work on your shaft. In fact, I used one to file down a DeWalt cordless motor shaft, so I could get it to fit into a 5mm coupler. I powered the motor up and pressed the file against it, and shaved it down in just a few seconds.
                      Duck
                      It's a small world, but I'd hate to paint it!
                      • saleens7
                        • 1130
                        ok, ill look for one...
                        just wondering...im getting a 3 channel futaba FM pistol radio, but what do people use the 3rd channel for?
                        • Rex R
                          • 1007
                          if you get some medium strength threadlocker and a tight coupler it can be a challenge getting the coupler back off the motor shaft...I needed a propane torch, fortunatly I was able to pull the motor out of the boat 1st :)
                          • saleens7
                            • 1130
                            i found a big file a filed away and eventually i got a small flat spot...i hope it holds..
                            im getting a 3 channel radioi system...what would be the purpose of the 3rd channel?
                            • DuckOfDeth
                              • 63
                              3rd channel can be used to activate 'drag chute' or to turn on 'interior fire sprinklers'
                              Duck!!
