Boat stands How to make?
  • SweetZ28
    • 1322
    Hi anyone have any good info on how to make nice boat stands without emptying the wallet?
    I am sick of the tiny ones they give you with the boats there so low the boats rudders always scrape the ground and stuff!
    THANKS
    WWW.PPRSLOTS.COM
  • dana
    • Mar 2010
    • 3570
    most people do the same as i do, plumbing pipe and fittings. its really cheap and works well
    • Diesel6401
      Memento Vivere
      • 4203
      Ben has a nice play by play breakdown https://fightercatracing.com/index.p...cles&Itemid=58
      - Diesel's Youtube
      - Diesel's Fleet
      • jac4412
        FE Addict
        • Jun 2010
        • 425
        SweetZ,
        I've also seen a few people use some nice balsa wood to and thick wood supports to make some stands... That would be another cheap alternative but the PVC piping is the way to go for me
        JAC4412 RC
        • siberianhusky
          • Dec 2009
          • 2184
          I usually make mine out of a home made wooden C channel the desired length/width/height.
          Coat of varnish and some pipe insulation on the top and your done.
          Use some knotty pine and route some nice corners and they look great for display as well.
          Drill a couple of holes on each side near the top and thread some heavy string to make a carrying handle that wraps around the sides of the boat to hold it in place.
          A black and decker work mate makes a great stable collapsable work table at the pond. Puts the boat at a nice working height.
          A piece of indoor outdoor carpeting under it makes it easy to find what you just dropped.
          Glad I can park my truck 15 feet from the running spot!
          • sailr
            • Nov 2007
            • 6924
            What is wooden C channel?
            Mini Cat Racing USA
            www.minicatracingusa.com
            • siberianhusky
              • Dec 2009
              • 2184
              Piece on the bottom and two sides. Just like a piece of iron c channel. like this. I_I
              Cat, mono, hydro, same style works for most hull types.
              • sailr
                • Nov 2007
                • 6924
                Got pics?
                Mini Cat Racing USA
                • SweetZ28
                  • 1322
                  WOW Thanks guy's i just got back from toying with 4 boats!!
                  I need to make taller stands why do they even bother giving you the stock stands the least they could have done was make them 2 times as high so nothing has a chance of hitting the ground!!!
                  Looks like the PVC is a cheap way to go about it.
                  THANKS
                  WWW.PPRSLOTS.COM
