Whats a good hatch tape?
  • roadrashracing
    • 1630
    I am using the proboat wide stuff and its falling off half way in a run. What else is out there?
    • 9481
    I love using clear electrical tape
    cheap and works great
    • lectriglide
      • 540
      Make sure to clean the taping area with denatured alchohol or some degreaser. Easy to get grease from cable lube and it will not stick good. I also like the clear electrical cause it "curves" well.
      • sailr
        • 7128
        CLEAR HOCKEY TAPE! Steven sells it here on OSE. Awesome stuff and doesn't leave any residue. I've tried the clear electrical but it doesn't hold nearly as well.
        Mini Cat Racing USA
        www.minicatracingusa.com
        • T.S.Davis
          • 6266
          Renfrew. Best ever.
          Noisy person
          • marko500
            • 862
            Renfrew hockey tape.
            Mark
            • keithbradley
              • 3671
              Where do you get clear electrical tape? Does in come in the 1" wide stuff? I used to have a roll of vinyl tape that was maybe 1.5" wide and it worked better than anything, but it was black so it looked terrible.
              I use the hockeyt tape too, which seems to work well on hot sunny days, but not as well when teh temps are cooler. It just doesnt stick well when its cold.
              www.keithbradleyboats.com
              • roadrashracing
                • 1630
                temp could have been my problem to, it was only 40 something
                • 6sHyper
                  <<<Surfs up!
                  • 640
                  i just use black electrical tape, sticks very well, even when a little wet, never a problem and best of all wont peel the clear off some of those crappy china hulls finish like the apparition. I've seen the hockey sock tape peel clear off the hulls before.
                  • Jeff Wohlt
                    • 2740
                    Hockey tape but had good luck with elec tape...colors to match the hull.
                    www.rcraceboat.com
                    jwohlt5362@yahoo.com
                    • FRED
                      • Jul 2007
                      • 232
                      Green electrical tape. I tried black hockey tape,that wasn't good. Black electric tape works if kept warm. I tried clear tape from LHS and after one usage, it remains on nail .
                      • dana
                        • Mar 2010
                        • 3660
                        electrical tape. best of all, home depot sells it for .59 per roll. never had a problem
                        • photohoward1
                          • 1781
                          Mark
                          Yes
                          • martin
                            • 2881
                            Electrical tape stretches around corners or bends very well, Hockey tape dosnt. I have both & prefer electrical tape. Another reason im not keen on hockey tape is where its 50% thicker than electrical tape water seeps in between the tape where it over laps its self on the corners of the hatch, You get a clear white mark along the over lap joint where the tape is not stuck. Martin.
                            • ozboater
                              • May 2007
                              • 419
                              black '3m scotch' brand elec tape... home depot... costs a little more but works great... the spendy white stuff is also good...
