There is a swordfish 240 in the swap shop for 200$ fyi
Falcon 41 on 10s?
we are going to do testing once we start building more boats, so an Eagle Tree is a tool we should getOriginally posted by Alexgar View PostI'd do a hydra ice hv so you had data logging if your buying new
but a Hydra would be a sweet direction
Originally posted by Alexgar View PostThere is a swordfish 240 in the swap shop for 200$ fyi
That would be awesome!Originally posted by Alexgar View Postcheck this out
http://fightercatracing.com/index.ph...emart&Itemid=1
is 180amp enough?
im reading 110 amps that sound do able
5692 that is
Features:
- High efficiency up to 95%
- Powerful 4-pole design
- High overload ability
Specifications:
Model: LBP5692/3Y
Max Amps: 110A
Lipo Cell: 5-13s
Max Power: 5500W
KV(RPM/Volt): 730KV
Resistance: 0.0130
No-load Current(15V) : 1.7A
Diameter×Length (mm): Φ55.8×92
Mounting hole depth: 8mm
Length of extend Shaft : 20mm
Shaft Diameter (mm): Φ6.0
Weight: 880g
Specifications:
Model: LBP5682/3Y
Max Amps: 106A
Lipo Cell: 5-11s
Max Power: 4500W
KV(RPM/Volt): 910KV
Resistance: 0.0117
No-load Current(15V) : 2.1A
Diameter×Length (mm): Φ55.8×82
Weight: 758g
Model: LBP5682/3D
Max Amps: 180A
Lipo Cell: 4-6s
Max Power: 4500W
KV(RPM/Volt): 1670KV
Resistance: 0.0040
No-load Current(15V) : 5.5A
Weight: 758g
That's the 730kvOriginally posted by Alexgar View Postim reading 110 amps that sound do able
5692 that is
Specifications:
Model: LBP5692/3Y
Max Amps: 110A
Lipo Cell: 5-13s
Max Power: 5500W
KV(RPM/Volt): 730KV
Resistance: 0.0130
Weight: 880g
I'm still leaning towards the 1000kv and that one shows more amp draw.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
No offense intended, but would it not be wise to listen to folks who have actually raced 10S boats over 40" long? There are a lot of them on this board, and spending the $$$ based on the opinions of folks with no experience is...risky. It's you money though...
I would not be too concerned about the amp rating of the Leopards. That rating is based on watts, not amps - pick the motor based on watts, and 5500 is better than 4500. It is common to exceed the manufacturer's amperage rating in boats. For example the Neu 2215 is rated for just 65 amps continuous, but we normally run 130-150 continuous amps through them. As long as they do not overheat they are fine. Use a big enough prop and you can load any of these motors to 250+ amps if you want - the motors won't like it though.
what did you find bro?Originally posted by Alexgar View PostI found one over seas for 151
we are still leaning towards the 5692 1000kv
this could be somewhat like Tyler's Conquest Open Cat.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
we could also runs twins, but I think single would be more simple
For the 5692 on 10s you may consider an s240 or x457..............................NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Any progress................???NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
