Conversion advice
    • 7512
    #31
    And a few more
    The motor mounts are 3/4" plywood cut to size ( trial and error ) and 5 minute epoxied to the hull and then painted in epoxy to waterproof. The engine mount is a piece of scrap aluminum I had lying around, bent and drilled to fit , took three tries to get everything right. All the water pickups and exits are stock and work fine
    • Diegoboy
      • Mar 2007
      • 7444
      #32
      Thank you again Doby! Now I have enough to get started. It was painful to look at that boat every day, and not knowing what to do or where to start. I truly appreciate it
      :) :D :)
      • lferguson
        • 227
        #33
        How are you keeping all that dry? are you coving the "exhaust"?
          • 7512
          #34
          No Problem , any time just ask and we will figure out whats best for your mod. I have two in the works right now, a V-24 with a LMT 3080 and a Blackjack 26 that I need to order a SV-27 speed control/motor package from Steven as soon as they are no longer on back order .
            • 7512
            #35
            The packs are sealed and the speed control is waterproof already, The motor has gotten wet , but with the proper drying , it runs great with no problems. The radio hatch is sealed with tape.
            • Diegoboy
              • Mar 2007
              • 7444
              #36
              Hey Doby.
              I read that this hole in the picture below is a drain plug. I haven't been able to locate a part# for it, nor have I been able to find a used one w/o buying a whole boat. What do you think of the Octura Auto Bailers in this location? I think I may have a problem with the angle of the surface on that side. any suggestions?
              • boater76
                • 574
                #37
                My dad got one of the Lumar that are smaller. The things weighs a ton and not much room for anything in it. The thing in fact starts to sink.
                Ken
                • Diegoboy
                  • Mar 2007
                  • 7444
                  #38
                  Sink? Was there a hole in it? or did it just sit very low in the water?
                  • hookedup
                    • 444
                    #39
                    nitro is out!!
                    doby, i was going to ask about the llumar when i seen the pic of your shop. my buddy and i just bought two of them and after two days of "breaking in" the motor, i think we are over it. these were our first ever nitro boats, and in less than 2 days we are already trying to figure out converting them to electric, but we thought there is not enough room, especially for the batteries. do you run in fresh water? we dont have any lakes or fresh water ponds here in hawaii, so we run in the ocean, and i can see the salt water eating up the electrics real quick. what prop do you run? thanks for all the pics.
                    OPP Racing "Other Peoples Parts!"
                    Island Boys Fast Electrics
                    • Diegoboy
                      • Mar 2007
                      • 7444
                      #40
                      Where's Doby? I saw him online last night, but he was gone just that quick.
                      • boater76
                        • 574
                        #41
                        It actually sat very low in the water. My dad said he is not happy with it at all. I will have to found out the weight and measurements.
                        Ken
                          • 7512
                          #42
                          Hi Guys , sorry for the late reply, was out with the girlfriend last night after setting up my new computer in the workshop,,,,got a new HP with dual procesors, 320 GB hard drive,,,,22" LCD,,,,loaded !!!!!!!!!!!!!!!
                          Back to reality; First off , the salt water will eat everything if not rinsed off right after running, I run in fresh water and always make sure the thing is bone dry after running . I seal the ends of my battery packs with A hot glue gun, keeps them nice and dry . hey do need a slightly longer cool down between runs though. Thats where having a good supply of packs helps.
                          The plug on the back is a drain plug , the auto bailer isn,t really required as long as when you do you mods, you are careful not to damage the inner hull, Pro boat does a pretty good job of making all of the chambers water tight and I have had no problems other than self induced.
                          As for hydros themselves, they do sit low in the water and are a very wet boat to begin with. even up on plane, they can be wet. I have never had a problem with this though, a bit of water does make in into the motor compartment on every run but its not a big deal. I added a foam seal around the cowling, (I'll attach a photo tonight after I get back from dinner with the family).
                          The SV 27 motor really makes this thing move, It runs on par with my SV and beats my friends Nitro version with ease. The weight of the two packs is evenly distributed in the layout I came up with. Although things are tight !
                          • Diegoboy
                            • Mar 2007
                            • 7444
                            #43
                            Thanks for the info Doby. Do you know where I can get my hands on that drain plug?
                            That's a nice PC you've got there. It must have taken you all of .00057 seconds to process that last post of yours. :p
                              • 7512
                              #44
                              Took longer due to operator input co-ordination issues .
                              The best spot to check is Horizon Hobbies as they are the distributor for Pro Boats, you probably won't find one on theur website, but if you send them An E-Mail to their customer service group, they might be able to help. If you have access to a machine shop, I'll send you the dimensions of the plug. If you are really hard up, I might be able to sweet talk the guys in our machine shop department to whip one up. They have hepled me in the past with a few of my "odd" requests !
                              Let me know how the searh goes and we will somehow work something out .
                                • 7512
                                #45
                                Just snooped on thePro Boat page and found this !
                                Drain Plug
                                PRB2239 by Pro Boat
                                $3.99
                                Add to Wishlist
                                Usually ships in 2-3 Business Days
                                More in this Category
                                More in this Brand
