PLEASE HELP ME get in the water
  • dascoadams
    • Feb 2011
    • 134
    plese
    i cant figure out what esc i have and how to program it..all i know is it needs a battery pack (no bec) and is 200a
    please
    PLEASE SEE PICS BELLOW THANKS
  • siberianhusky
    • Dec 2009
    • 2206
    That link just leads to a forum index, not sure what we should be looking at here.
    • dana
      • Mar 2010
      • 3660
      looks like a himodel or something. have you tried just plugging it in and hitting the throttle?
      • dascoadams
        • Feb 2011
        • 134
        yes but its like the timming is off or something...im running 6s with a 7xl...and i'd put up pics but it wont allow it
          That is NOT an appropriate motor for 6S. It will burn up any ESC. It is hot for 4S, if you insist on using it of 6S you will be sorry.
          If you post a link to a photo or tell us what the boat is we can be more helpful. I do not have the time to go through another forum post-by-post to find yours. You can post pics here. If you want help, help us.
          • m4a1usr
            Fast Electric Addict
            • 2036
            Lets start by the link provided in this thread doesnt take the folks here to where you provide any details. I had to go to your thread under the AquaCraft UL1 topic to see any details. Next,...... it sounds like your trying to run a 6S speed controller at 6S. Aint going to work. I have owned lots of the Himodel GX-200, Suppo copies and 6S is just not right. Next,......... what radio are you using? I have never been able to any of my GX-200 speedos to operate unless I used a PisTix adapter. Thats been my experience. Lastly, using my math on a 7XL motor and 6S produces 52k rpm. You will blow it up. Maybe not on the bench but if it does arm,...........and you get on the water,...........and you have not over propped the hull,................the inside of your hull will fill with the magic smoke from what ever cooks off first. Might be the speedo,.......might be the motor. But your going to blow something up.
            So before we go any further could you please provide some more information please? I'm not being sarcastic, I'm not trying to sound of critisim. But I do think you might want to reconsider what you are doing. Just my 2 cents and not worth too much more.
            John
            Change is the one Constant
            • dascoadams
              • Feb 2011
              • 134
              It's a ul1 superior
              2 - 3s 1p 30c 4000 mah in series 6s 8000
              1 - 7xl
              1 - esc ? 200a
              1 - Traxxas 2.4G 3ch. Radio and receiver
              1 - .078 wire drive and coupler
              1 - grim racer prop L38x55
              • m4a1usr
                • 2036
                Originally posted by dascoadams View Post
                It's a ul1 superior
                1 - 7xl
                1 - esc ? 200a
                Got some good stuff there! Any chance you could go down to 5S? I know it might not be in your inventory but even using a smaller 38mm prop its still on the edge. Most of us tend to go with 4S and a 40mm or so prop. I'm running a 42mm in my UL1. Since you got good stuff I'm guessing your savy. Lets get down to brass tacks. Do you know why the speedo is not arming? End points wide open, following instructions, getting the right tones?
                John
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  Can you post pic of the ESC..............tha ESC was the main concern right..............????
                  As stated, 6s is not appropriate at all................4s is tops you want to run.
                  • video200
                    • 840
                    you dont get it both ways mate. 2 X 3S 4000 wil still only give 6S1P 4000 mah
                      Yes, the OP is running 30C cells at 4000 mAh, so anything over 120 amps will stress the cells. And he WILL run over 120 amps with that motor on 6S. He can safely run 3S - if the ESC will arm - but then his speed will be about the same as stock. Best to either go 4S or get a motor with a much lower Kv - 1500 would be much more reasonable for 6S.
                      • dascoadams
                        • Feb 2011
                        • 134
                        John
                        No I'm not savy with the boats yet ,I have been in the rc world for years with cars and planes...but most of my experience is with 1/8 buggies. I've have a vxl brushless system for a little over a year and lipos about as long. Because that system was rtr I never really had to deal with trimming and such. I bought the boat with the 7xl and two 200a esc's .
                        Then upon reading about diesels 7xl I bought the wire drive and used the same couple and vacumen hose cap to keep grease out of the hull(awesome video and very fast)
                        After that I seen the carnage of the prototype ul1 with the 7xl I bought the prop used cause the guy said it was fast
                        The carbon fiber sceme I made up from my car building experience
                        And the deck lid I made from the side of a mail tote
                        I hope to get more picks up so please bare with me ....and one final thing is 4s is what was used with the boats I copied...I just figured that the 200a esc was good for 6s
                        • dascoadams
                          • Feb 2011
                          • 134
                          Thank u m4a1usr for the kind words...I will probably use 4s...and also thanks to all for the quick replies
                          • dascoadams
                            • Feb 2011
                            • 134
                            This is what I have to work with so far
                            • Flying Scotsman
                              Fast Electric Adict!
                              • 5195
                              Laddie, you have some great advice. I might suggest the next time that you be directed by some lads that know their stuff prior to purchasing a dubious setup.
                              Douggie
