esc problem
  • ron1950
    • 3024
    esc problem
    i have a spectrum dx3s tx and a mr3000 reciver....turnergy 120A ESC...i programed the esc to forward only and 4cell etc....the problem is that when i plug in batteries for normal use the motor runs about quater throttle till i hit the break....the only way to stop this is to use the sub trim and put it to b 14 to make it stop auto runing......is there anything i did wrong or a way to fix it? thanks
  • b.mcdaniel.2009
    • 1641
    You need to set your throttle at 0 and calibrate the reciever to the ESC.
    Hold the trigger full throttle...Plug in batt...Beep beep... let off throttle...One more beep...Then your good to go.
    ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
    • ron1950
      • 3024
      thanks ill give it a try
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3278
        I tried that with my two 120's in my twin and they keep doing as Rons did. It didnt work,so I just deal with it and blip the throttle and its done and good to go.
        • ron1950
          • 3024
          larry give it a try again ...mine finally worked ...one took 3 trys but worked after the third try...other one worked first time....remember to hear 2 beeps and let off trigger and it should catch......someone said its different with a futaba ....dont know about that one
