Epoxy glue
  • JayB8764
    • 18
    Epoxy glue
    what is the best 2 part epoxy to use for mounting things (motor mounts, battery trays etc) to the inside of a fiberglass hull?
    Jay
  • JimClark
    • 5913
    West Systems
    Billy Graham
    • JayB8764
      • 18
      thanks jim
      • JimClark
        • 5913
        Actually System three has some good products also
        Billy Graham
        • siberianhusky
          • Dec 2009
          • 2206
          Those are the two I use, System3 is a bit easier to use as it mixes at a 1:1 ratio and comes in squeeze bottles, I use west for laminating, lay ups, actually any time I need a bit more than a squeeze.
          • Chilli
            • 3204
            For mounting stuff (motor and servo mounts) I use JB Weld. I also lay down some masking tape down along the edges of the mounts before applying the epoxy. I pull it up after the epoxy sets for an hour for a nice clean installation.
            Mike Chirillo
            www.capitolrcmodelboats.com
            • Skipster
              • Apr 2009
              • 110
              +10 for CHILLI (Nautiboyz)
              Mike does excellent work
              here is my work before and after his
              tutelage
              Hope this helps
              You can lie to mother Nature
              but You can not fool father Physics
              The more I learn, the more I know I don't know
              • Chilli
                • 3204
                Paypal sent as a gift Skip.
                Anyone can glue parts together with a few tips. The guys that scratch build boats and make their own plugs are the real craftsmen in this hobby!!!
                Mike Chirillo
                • line6
                  • 510
                  West is the best. I like to use 406 colloidal silica as a filler.
                  Jason sims
                  • LarrysDrifter
                    Big Booty Daddy
                    • May 2010
                    • 3416
                    Ive had great luck using Z-Poxy 30 minute for for motor mounts. Its cheap and it works good. For mounts that only support the front of the motor(no rear support),I cut up some fiberglass cloth into very small shards and mix it in for extra strength. Ive never had any kind of mount fail using Z-Poxy. I know West System is the best,but its also costly. Use what you can afford is my opinion.
                    • line6
                      • 510
                      ya its not inexpesive, but for the small amount that i use its not to bad. I use a little digital scale and weigh out small amounts.
                      Jason
