Eagle tree elogger v4
  • JPriami
    N4FOX
    • 1711
    I am in the market to get a data logger. I am looking at Eagle Tree elogger v4. 150amp version.
    Are these good?
    What happens if your system ends up drawing or spiking over 150 Amps when you test it out? Does that fry the logger? Or just go off the chart?
  • Diesel6401
    Memento Vivere
    • 4391
    Are these good?
    I just got one last month and I love it... AWESOME TOOL to have and has helped me alot so far. I went to almost 180amps with no issue, the unit did get pretty hot though. I would say go for it, I don't think you will be disappointed. I also waterproofed mine and I grabbed a extra temp sensor and brushless rpm sensor. It took a little playing around with it to get the charts to work the way i wanted them too but all in all I am 100% happy. I want to grab the gps expander whenever I get some extra cash.
    - Diesel's Youtube
    - Diesel's Fleet
    • JPriami
      N4FOX
      • 1711
      Thanks. Ive got a back order of one. Looking forward to getting it. I think it will be really useful tool. And the addons look very promising too.
      • gultch
        • 66
        wheres the best place to purchase one of these
        genesis leopard 4074 2000kv t180/ hk vanquish cc1717 hydra 240/ fibreglass carbon hydro 38" build in progress
        • JPriami
          N4FOX
          • 1711
          Best price I have found is at advantagehobby.com $70
          • gultch
            • 66
            thanks j
            • GP73
              • 546
              I got mine here on OSE:
              http://www.offshoreelectrics.com/pro...PRV4-LEADS-150
              But it's out of stock now.
              • JPriami
                N4FOX
                • 1711
                They are out of stock everywhere. Should be back in soon. Then I'll have one at last.
                • ncornacchi
                  • Jul 2009
                  • 256
                  I have been using both ETrees for a while now, the style with deans plugs and the 150 with leads...The only problem is the extra battery and esc wire that you have to use to wire them into boat causes excessive resistance...One time, last year, EagleTree shipped me someone elses order by accident, and it was current donuts! Made me think that you could run the ET off of a battery to power the module and GPS without intercepting the battery main leads...Anyone using these CT's?
                  • oscarel
                    • Dec 2009
                    • 2373
                    I used the elogger and the one I had would clip anything over 180 amps. Be careful running those over 150 because I also had an instance when one of the battery leads unsoldered from the board. I purchased the USB flight recorder that uses the "donut" current sensor that will record up to 300 amps and I'm very happy with it. It is powered off the servo leads so it doesn't affect the total battery lead lengths.
                    • ncornacchi
                      • Jul 2009
                      • 256
                      That's what I'm talking about! No leads unsoldered, no draining of main packs..No using extra battery wire that contradicts keeping wires from esc to battery short...
                      • egneg
                        • 4759
                        Inductive pickup - much easier than running it in series but I wonder if the max readings are as accurate.
                        IMPBA 20481S D-12
                        • ncornacchi
                          • Jul 2009
                          • 256
                          We use the larger ones in work...extremely accurate, not sure of hobby grade, but can't seem to find them on ET website, yet they shippped me some poor guy from Norway his Ct's instead of my order..We swapped our stuff, but i should have asked him if he was using them from one of the sensor ports
                          • oscarel
                            • Dec 2009
                            • 2373
                            They're under the plane recorder http://www.eagletreesystems.com/Plane/plane.html, scroll down to accessories. They have 100, 140, 300 amp ones. I got a 100 amp off ebay for $5.00 new.
                            • JPriami
                              N4FOX
                              • 1711
                              Just ordered the elogger v4, two temp sensors, GPS, brushless rpm and the LCD screen. So glad they came back in stock. And guess who had them first on my email list? Steven at OSE here. Thanks Steven!
