what flex and tube to run on 1/12 hydro
  • 62 bugzilla
    • Mar 2008
    • 341
    I have a budweiser hydro I'm converting and I'm putting a 8xl in it on 4s lipo and wanted to know what flex and stuffing tube to put in it? I might upgrade to a neu motor later for more speed and power so might need it allittle bigger for that. From what I read I shouldn't run a liner in it either ?
    SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieser
  • Alexgar
    • Aug 2009
    • 3701
    .150 is what I had in my Elam with a 3/16 stub and an after market strut
    • 62 bugzilla
      • Mar 2008
      • 341
      Should I go with the .187 to handle extra power later or is that over kill? I see they both work in the same stuffing tube .150 and .187 when ran without a liner.
      • jingalls007
        • 1172
        Unless you plan on going much larger in motor size, anything above a NEU 1515 or comparable, the .150 flex will work fine. 1/4" brass w/teflon and you're good to go. If you decide you want to run a .187 flex cable you can always remove the teflon lining. Running with or without teflon is a matter of preference.
