epoxy or c/a?????
  • crazzy maxx
    • Dec 2007
    • 498
    epoxy or c/a?????
    i have herd people using epoxy or c/a glue to combine there hulls.
    witch is better and easier to work with?
    im building a scat cat and wanted to know witch is better before i start combining the hull.(build up will be posted around christmas time)
    thanks
    Brett
    snort pixi sticks=symptoms-:
  • Eyekandyboats
    • 1935
    I used a medium CA glue, If you put enough one and don't use accelerator it works fine,
    I have done 3 scat cats and it has worked for every one of them.
    EYEKANDYGRAPHICS
    www.rclipos.com
    • SJFE
      • 4867
      Taylor what brand of ca are you using? Also what is the setup time like. I would like to use a single part bonding agent as long as it has some work time. I love the DC but its expensive and messy to use all the time.
      • crazzy maxx
        • Dec 2007
        • 498
        witch c/a glue are you using???
        • Eyekandyboats
          • 1935
          I use medium ( purple bottle) insta-cure
          Zap CA sucks for what you are doing.
          insta-cure is the best
          EYEKANDYGRAPHICS
          www.rclipos.com
          • SJFE
            • 4867
            Ok I will grab the medium. Thanks man :).
            • tylerm
              • Nov 2007
              • 310
              I dont like CA
              I'm not the biggest fan of using CA AT ALL on my Abs hulls.
              CA make the abs brittle and very prone to chipping and cracking. I know quite a few people who have given up on Abs hulls simply because of cracking and splitting from CA. Also CA has a very inconsistent grip on abs, the previous owner of my OM26 ca'd velcro down. Parts of it would come off like it wasn't there and some parts had to be grinded off. I know Randy Naylor says to use CA but i am quite against CA on abs(as i said at the start).
              5min epoxy(well any epoxy for that matter) doesn't like sticking to abs much either.
              For Abs to abs applications(like joining hulls and adding support) i use IPS weld-on #16 for joining acrylic(i was told by abs fabricators this is the stuff to use, just be careful with how much you use). And for abs to anything else i use selly's urethane bond(works ok just don't sand it).
              Just my opinion .
              Tyler.
              • Eyekandyboats
                • 1935
                well who CA's down velcro??
                that is a very porous surface and will just have to be chipped off.
                There is a technique to gluing a hull
                You first put glue on the main surfase you are dealing with, then put it to the deck rub it around pull it apart. Blow on it for a second to let it get tacky then push it together in the finial places.
                I have never heard about it chipping. with accelerator or kicker it will chip.
                EYEKANDYGRAPHICS
                www.rclipos.com
                • crazzy maxx
                  • Dec 2007
                  • 498
                  eyecandy
                  dou have any pics of your building of your scat cat????
                  • SJFE
                    • 4867
                    Prep work when bonding ABS is a must imo. I find with any smooth surface you need to ruff it to get good adhesion and a permanent hold. Using to much ca will cause some of the issues I see mentioned above also.
                    • Eyekandyboats
                      • 1935
                      I have loads of pictures from building my scat cats.
                      but none show me gluing. I didn't think it was that important.
                      Yes lightly sand the ABS with a 200-400 grit paper
                      EYEKANDYGRAPHICS
                      www.rclipos.com
                      • crazzy maxx
                        • Dec 2007
                        • 498
                        eyecandy. can u send me pics?
                        when i start building can u send me pics?
                        so medium c/a glue and sand abs where every glue goes?
                        anouther question. what grit should i use to sharpen the hull corners?
                        • Eyekandyboats
                          • 1935
                          Yes sure.
                          Just email me at
                          eyekandyboats19@aol.com
                          That is also my AIM
                          To sharpen the corners, I built them up with JB and then filed them sharp
                          EYEKANDYGRAPHICS
                          www.rclipos.com
                          • crazzy maxx
                            • Dec 2007
                            • 498
                            good idea....
                            thnx for the info
                            • tylerm
                              • Nov 2007
                              • 310
                              re:
                              Well for someone who uses ca on their boats what do you use?
                              Again i say ca is not good for abs, as it attacks the plastic and makes it brittle, even when you don't use kicker.
                              The ips weld-on very slightly melts the two abs parts together which ends up making them like one piece.
                              I have actually made a motor mount for my 700 out of abs laminated together with IPS weld-on which works brilliantly(and is tough as nails).
                              The previous owner of the boat had his motor mount stuck down with JB weld and it came off at a SAW event just before he taped up, which proves my point that epoxy doesn't stick well to abs.
                              Just speaking from experience,
                              Tyler.
