thrust bearing help
  • the savy fluxer
    • 83
    thrust bearing help
    i have a thrust leopard 4074 on its way and a thrust bearing also, just wondering if someone has a pic of how to mount it properly.
    thanks
  • egneg
    • 4664
    Just put it on the shaft before the coupler.
    IMPBA 20481S D-12
    • the savy fluxer
      • 83
      touching the motor and the coupler?
      • m4a1usr
        Fast Electric Addict
        • 2032
        Should look like this if done right. Since there is no significant loading on the install method we use for FE boating you do not have to preload the bearing as recomended by bearing manufacturers. Here is some decent info from SKF on thrust bearing loading. http://www.skf.com/files/151318.pdf
        John
        Change is the one Constant
        • the savy fluxer
          • 83
          thank you it makes sence now
