Can i put a different rotor in it
  • TotalPackage
    • 622
    I de maged my kb 45 motor. Can i put a rotor from a different motor in it as long as its the same size?
  • m4a1usr
    Fast Electric Addict
    • 2036
    Absolutely. Most motors (all that I know of) use the exact same rotor in a manufacturers series. An example would be the Neu 1515 motor. It doesnt matter if you have a 0.5Y or a 4D the rotors are exactly the same. As long as the end play is adjusted so that the rotor is adjusted to be centered in the motor iron you are perfectly fine. So you can take the rotor out of a 540xl can thats a 6T and put it inside a 17XL without any issues. Just a little motor magic!
    John
    Change is the one Constant
