HK Vanquish
  • Diesel6401
    Memento Vivere
    • 4203
    Originally posted by GP73 View Post
    Hey Diesel, are the trim tab mounted flush with the hull?
    The trim tabs are mounted slightly below the hull. I will be moving them up so they are flush with the bottom of the hull.
    Originally posted by Daniel2000 View Post
    then would you recommend to run a 5s with a higher kv motor?
    like the 1450kv or the 1500kv or even 4s with the 2200kv?
    that would put the ESC in a safer voltage zone?
    since I already have the ESC, I would like to still use it and make it last for a bit, and not burn it in my first run
    and thanks for the advise
    I think (not 100%) sure Forescott ran a 180 with a leopard 5692 on 6s with good results. Like I said it's hit or miss some have had no problems others many problems. I just won't be risking it. The 2200kv would be too much kv for a hull this size IMO. I plan on running the 1500kv on 5s & 6s. You maybe able to get away with the 1500 on 5s on that esc. Not sure the speeds though which is why I plan on trying both 5s &6s on that motor. Hopefully that makes sense.
    - Diesel's Youtube
    - Diesel's Fleet
    • GP73
      • 544
      Bummer, I guess I'll have to drill new holes in the hull to get that...
      But thanks for letting me know Martin!
      Originally posted by martin View Post
      On my Osprey their about 1.3mm above the bottom of the hull when pulled all the way down & about 3.5mm above when lifted to their highest. Martin.
      • 785boats
        Wet Track Racing
        • 3169
        Martin/ Diesel/GP73.
        Trim tabs are best bolted on about 1mm above the bottom of the transom.
        They cause less drag that way.
        You may be able to slot the holes in the trim tabs rather than try to drill new holes in the transom. Maybe?
        Paul.
        • GP73
          • 544
          Yes, that's what I was thinking initially. I'll take them apart again and check how much I can drill there. I'm not going to run her for a while anyway, need to reinforce and put rails first.
          I can't believe they would screw up something that simple though.
          Diesel, have you seen the propeller they ship with it? What a joke...
          Paul.
          • Diesel6401
            Memento Vivere
            • 4203
            #35
            Paul.
            I think I should be able to just slot them and slide them up. I will see what I can do and reference the 1mm spacing you suggested. Haven't had any hobby time lately to really check it out.
            I didn't even take it out of the bag yet lol.... I have 0 intention on using it lol
            - Diesel's Youtube
            - Diesel's Fleet
            • GP73
              • 544
              #36
              It's just funny to look at, you can bend the blades by touching them, not even pushing too hard...
              it should probably just go straight to the thrash.
              • Diesel6401
                Memento Vivere
                • 4203
                #37
                Just bought a CC1717 for this bad boy. Went a complete different route lol.
                - Diesel's Youtube
                - Diesel's Fleet
                • 785boats
                  Wet Track Racing
                  • 3169
                  #38
                  I had the same thoughts about those props too. Sat in the prop box for ages.
                  But then, as a challenge I decided to set up a 25"hull to run 6 minute heats on 1 x 5000mah pack like they do in Europe & Hong Kong.
                  I tried many props on the 1800kv outrunner in the boat. All pulled the battery down too low before the 6 minutes were up. That prop, however, was just as fast & left enough in the pack to be acceptable.
                  13% was the average, with a peak current draw of 47A during the 6 minutes.
                  Surprised the hell out of me.
                  Haven't had any trouble with it bending.
                  I only say this because you may find a future use for it. You never know.
                  It's really a heavily de-tongued & back cut prop.
                  Cheers.
                  Paul.
                  • Diesel6401
                    Memento Vivere
                    • 4203
                    #39
                    Cheers.
                    Paul.
                    I got one with a different HK boat. I used it as a practice prop for sharpening and balancing come out really nice, just never planned on using it lol. I think OSE might sell them. I will S&B this one as well, once again not sure if I will actually use it. If you say they work maybe interesting to try.
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3480
                      #40
                      Me Too!!!
                      Pete Z made a very cool mount for me.
                      Planning to run a swordy 200 on 6s2p
                      • Diesel6401
                        Memento Vivere
                        • 4203
                        #41
                        Originally posted by FighterCat57 View Post
                        Me Too!!!
                        Those rails are sick.. May I ask where you got them from?
                        I plan on running 5s2p & 6s2p and I would like to pick up one of the new CC ice speedo's. I do have a swordy 200 laying around also though.
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3480
                          #42
                          Pete Z did these.
                          I'm having some new ones made that have the name actually cut out of the metal.
                          Cool stuff.
                          • Diesel6401
                            Memento Vivere
                            • 4203
                            #43
                            Pete Z did these.
                            Cool stuff.
                            They came out amazing! Once i get my motor, I will figure something out. I may have to talk to Pete
                            - Diesel's Youtube
                            - Diesel's Fleet
                            • RIPFENCE
                              • Sep 2009
                              • 1332
                              #44
                              holy ^@%@$@@* those rails are the sickest....
                              "FE" STANDS FOR FRUSTRATING EXPLOSIONS
                              • FighterCat57
                                "The" Fighter Cat
                                • Apr 2010
                                • 3480
                                #45
                                Are you going to do a carbon fiber layup? The hull seems a bit weak to me.
                                I've managed to avoid doing them up until now, but think this hull needs some help.
                                I may have an extra set or two of those stringers made soon.
