Here is my theory so far.
The existing hull runs a 540-S can and works well on 3S with a 100A esc and about 3600mAh pack. After 6 passes the motor is hot (watercooled) the esc is well warm and the packs are warm-hot. I am happy with this setup, I know props change it all.
My big cat runs a pair of 36mm dia outrunners on 100A escs a side off a 4500 mAh pack. This one comes in with motors and escs hot (aircooled) and the packs well warm but not hot.
I reason that as each side gets half off the 4500 mAh so 2250mAh each side and the power systems survive.
If you are still reading then I have your attention.
I know the cat is on twins but suspect the effort on the power system is similar to a hydro or close to a rigger.
With this info I am prepared to have a crack at repowering the rigger, with a new tub as well, with a setup that will be close to what the big cat runs.
This will be a L size IR motor or a 36mm OR motor with a 120A esc and about 3000-3600 mah of pack.
It will be a 4-5S setup to keep amps down and should be a royal hoot.
FWIW the rigger will, as riggers should, run a nuts high rpm. 35-40krpm......maybe more
Anyone care to point out the errors of my thinking.
