pursuit motor swap question
  • the savy fluxer
    • 83
    i bought a pursuit mono hull a couple of weeks ago and i am swaping out the 3660 size motor for a 4074 motor. i am wondering if the upright pieces of the mout are the same distance apart for to 4074 mout as they are for the 3660 mount.
    reason i am wondering is i already reinforced the mount for the stock motor and i dont want to dremel it out if i dont have to.
    thanks.
  • GP73
    • 546
    The spacing is the same for the 40mm ring, in theory you don't need the back ring, a zip-tie might suffice.
    thanks.
    • Diesel6401
      Memento Vivere
      • 4391
      It will bolt right into the stock mount. The aft support ring you have is a 36mm, it will not work for the leopard. Also the Leopard water jackets are very slim and fit into the stock mount no problem. The larger jackets don not fit without changing the mount or modding the stock mount.
      If you are using the stock 4mm drive system it will not work very long. The torque from the Leopard motor will destroy that 2 piece 4mm square drive very quickly.
      http://forums.offshoreelectrics.com/...0&postcount=36
      http://forums.offshoreelectrics.com/...hp?albumid=300
      - Diesel's Youtube
      - Diesel's Fleet
