Mystic C5000 motors
  • jjrctech
    • Feb 2011
    • 187
    Mystic C5000 motors
    Mystic C5000 44" I was going to power the boat with neu 1527 1527 1.5D 5mm shaft (kv 1500) , but those motor are out of stock ,
    would these work?? and have the same speed and power??
    1D 2160 Kv 8mm Shaft , 1Y 1250 Kv 8mm Shaft ??
    Thanks
    --> 54" fountain - Bonzi boat. http://www.youtube.com/watch?v=_cxR6yDRJXw
  • RIPFENCE
    • Sep 2009
    • 1577
    is this a single or twin setup?
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
    • jjrctech
      • Feb 2011
      • 187
      It would seem to me you put in the correct volt batteries and it would be about the same power?
      1D 2160 Kv 8mm Shaft , 18.5v 39,960rpm
      1Y 1250 Kv 8mm Shaft 29.5v 37000rpm
      1527 1527 1.5D 5mm shaft 25.9v 38850rpm
      thanks
      • jjrctech
        • Feb 2011
        • 187
        twin setup 2 motors
        • jjrctech
          • Feb 2011
          • 187
          am looking to make the fastest boat possible
          Thanks
          • RIPFENCE
            • Sep 2009
            • 1577
            either the 1250 or the 1500kv i would choose...the d winds run hotter though and are more suited to lighter boats...but since you have a twin setup it will work i believe...the 1250kv is definately the safest choice though...speed is going to be within 3-5mph if i were to guess through the different rpms..but the higher kvs are going to pull more amps
