prop shaft spacer
  • BONZ
    • Dec 2010
    • 27
    prop shaft spacer
    on the prop shaft, between the prop dog and strut there is a flat washer (nylon, plastic, neopreme?) where can you buy them, it's for a 3/16 prop shaft.
  • Diegoboy
    • Mar 2007
    • 7443
    Teflon.
    Near the bottom of THIS page
    • dasboata
      • Dec 2010
      • 3972
      It is called a thrust washer,,, you can find 3/16 thrust washers here on OSE and there are a few different types
      • Rumdog
        • 6667
        I wouldn't use one unless youre running a wire drive or that Asian style 4mm flex with captured prop shaft. Otherwise, you need a gap between the drive dog and strut to accomodate for cable shrinkage.
        • BONZ
          • Dec 2010
          • 27
          Ok thanks guys, waiting on parts now, got new driveshaft coming
