how did I smoke my new feigao
  • dasboata
    • Dec 2010
    • 3972
    I bought a new 540 10xl the water cooling was working fine I had on a X442 the motor melted a connection and had a smell of smoke in it I went home charged up my lipos re did the connections with silver solder then connected it lots of smoke came out of the can well I would not be surprized if I might have done some thing wrong but I did not see anything I was running the boat on 5s2p 4000 (I hope I have that right 2 400 cells wired in parral to give me 2 times the 4000ma the boat was running wet ,,if that is any help ,,Please help should I just get a Neu motor thanks chris
  • RIPFENCE
    • Sep 2009
    • 1577
    you did do positive to positive and negative to negative correct? i am hoping you did not connect in series thinking you were doing parallel..it would surely cook if you put 37.0 volts 10s to it by accident..did the motor run for any length of time? just trying to do a little detective work
    thanks
    rip
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
    • GP73
      • 546
      Too big of a hull (what size)? Too much weight? Boat running too wet? Just throwing ideas around.
      Feigao are far from being efficient, Leopards are much better if you don't want to try Neu right away.
      Also a T600 1400Kv should give you plenty of torque on 5-6S.
      But wait for the experts opinion.
      • GP73
        • 546
        From the pics looks like a T180 ESC, I think he would have noticed right away the caps exploding as he connected the batteries...
        thanks
        rip
        • dasboata
          • Dec 2010
          • 3972
          MM hull,, and I did not hook them up in series was running the boat for less then 10 min everything was ok then the wire came loose the soilder melted ?????
          • RIPFENCE
            • Sep 2009
            • 1577
            good point
            • dasboata
              • Dec 2010
              • 3972
              thanks
              rip
              the boat was a little wet !!!
              • 6sHyper
                <<<Surfs up!
                • Jan 2011
                • 640
                What kind of connectors are you using??? what size bullets on motor-ESC?? they appear small, 5.5mm bullets or bigger, i would be more than inclined to say this is a direct result of a poor connection between the motor and ESC.
                for the record i have ran my 10xl on 6s1p 5000mah with t180, x442 with no problems, hottest temp i have had on motor was 130f, 3 full runs, no issues. using 5.5mm bullets..........................
                • GP73
                  • 546
                  It might have been just too much amps for the motor to handle, the bullets melting is a good indication of high amps flowing through.
                  I think a Leopard 4082 might be a better choice, but I'm a newbie myself, so wait for someone with more expertise before you start buying stuff.
                  Feigao motors are really crappy, I smoked 2 ESCs because of high amp draw.
                  • 6sHyper
                    <<<Surfs up!
                    • Jan 2011
                    • 640
                    i dont think the boat being wet had anything to do with it, although you need to adress that and seal up that T180 for the future.
                    BUT you need a new motor now, so check out the swap shop i have a 1512 1.5y 1800kv with jacket up for grabs, or i'd sell my 10xl as well...........
                    • forescott
                      Hopelessly Addicted to RC
                      • 3009
                      The feigao xl should be fine for the MM. Guys run L-sized 540 cans in these no prob. I hope you get it worked out. I'm swapping the castle motor out of mine, and was planning on putting a feigao xl in as a replacement. I have the t-600 outrunner as well, it would be a good choice IMO.
                      • GP73
                        • 546
                        Same hulll? Also 2x 5S 4000mah packs can add up quite a bit of weight compared to a 6S 5K or 2x 3S 5K.
                        Dasboata has experience with boats, so I'm assuming it wasn't the driveline binding or anything like that.
                        Maybe the motor was just bad? It happens.
                        • 6sHyper
                          <<<Surfs up!
                          • Jan 2011
                          • 640
                          Mines in an Apparition, 2x3s5000 packs in series, sure the motor could have been faulty thats definately feasable, but those motor-Esc connectors look small, and/or they were faulty i bet.
                          • GP73
                            • 546
                            So maybe the connectors de-soldered because they were small and then made contact to each other?
                            But then the ESC would be gone as well, no?
                            • dasboata
                              • Dec 2010
                              • 3972
                              this is going to be the problem I am guessing
                              Click picture for details! Product ID: dh-gpmm3114
                              4.0mm Male Bullet Connectors (3 Pack)
                              In Stock: 41
