i just got a 5 mm motor shaft and my venom king of shave shaft prop is only 4 mm should i buy the 5-4mm shaft universal joint or should i change the power trim? tnx
5 mm motor in king of shave
If you have a 5mm shaft,you probably have more powerful motors than stock.Id upgrade the flexes or use wire drives.Dont use u-joints.What motors do you have?Im assuming its still a twin?
A 380 Feigao has an 1/8" motor shaft,not 5mm.www.rcraceboat.com has driveline parts for the EKOS.OSE has parts too,you just need to know what you need.You can use the stock stingers,just upgrade the stock flex cable to a wire drive or a bigger flex.Is this boat still a twin?If you get the wire drives,OSE sells Octura 1/8"x.062 collets.Or rcraceboat has ALL the driveline parts you need for your boat.Just click on the EKOS upgrades and you ll see.Also,there are threads on here for the EKOS under the Venom RTR boats section.Have a look and a long read.You will find many answers and pictures that will help.
The very 1st step you should take with this boat is to do research.Read up as much as you can.Others and myself will be glad to help anytime,but research pays.
