please look cat/tunnel owners
  • steveo
    • 1595
    this is my lso boat trying to finish up, i bought it 3/4 the way finished from shockerman 80 a few years ago,
    - should i remove this air dam thingy?
    -it will cause lift i need or hinder the performance?
  • steveo
    • 1595
    more pics
    • Eodman
      • 1285
      I would ask shockerman what its purpose is.
      On my toysport Jolly the maker of the hull created a wedge that helps keep it from
      porpoising when at higher speeds! So speak with the man first!
      We did it with a Bang!
      Cats Are Where It's At!
      • NativePaul
        Greased Weasel
        • 2770
        Its well clear of the water so isn't doing anything hydrodynamically, looks too small to be of much use aerodynamically.
        My guess is that's its just a spacer, a way to use a standard length strut on a cat built with a deep tunnel to enhance its rough water ability.
        Check with Shockerman though.
        • sailr
          • 7128
          You run your stuffing box through there! It is not a lifting surface at all since it is inside and above the sponsons.
          Mini Cat Racing USA
          www.minicatracingusa.com
          • steveo
            • 1595
            thats what i think a spacer you can see where the 4 holes for the octura strut was i pulled it off right before the pic, i am going with different hardware now so i didnt know if there was a higher purpose or just an aid for mounting the hardware
