Tandem Wing Hydro balance point
  • Mathieu
    • Apr 2009
    • 30
    Hi all,
    I'm building a 1:8 scale hydro with tandem wing design and I would like to get some advice regarding the balance point.
    Here are some shots from the hull :
    I'm not sure what motor I'll choose, but hte power will be provided by 8S2P 5000 40C lipo and ESC will be a 40.160WK.
    So my main concern for now is : where should be set the balance point for this kind of design ?
    The builder of the hull said to place it as forward as I can : from the end of the sponsons to up to 50mm in front of the end of the sponsons. I'm suprised because I always seen the balance point set between the end of the sponsons and the back off the hull.
    I owned a H&M Lifter several years ago and I set the balance point to something like 5 or 15% (can't remenber exactly) of the afterplane, but the design of the 1:8 is not the same so I don't know if the same rule of thumb apply...
    I'll certainly have more questions later when I'll begin the build.
    Best regards.
    Mathieu
    CT06 U14 2013
    TP 5650/850, Castle Hydra Ice2 HV 200, 10S2P 5000 40C, X457/3 Andy Brown detongued and cut down to 55mm.
  • carlcisneros
    • Jan 2010
    • 1237
    who makes that hull?
    thanks
    • Mathieu
      • Apr 2009
      • 30
      Hi carlcisneros,
      The hull come from MPM : http://www.mpm-hydros.de/
      Mathieu
      CT06 U14 2013
      • carlcisneros
        • Jan 2010
        • 1237
        oh cool
        will check it out
        thanks
