need cat hull suggestions
  • DyrtyByrd
    • 163
    hi all, im looking for a cat hull for my power system i have a 1500kv motor , 100 amp spedo and 2 5000mah 2s batts looking for something in the 26 to 32" range
    and really didnt want to spend more than $200 i was looking at the R2hobbies stuff but wasnt sure about the quality of those hulls has anyone ever used them
    or does anyone have any other suggestions thanks
  • keithbradley
    • 3671
    Check out fightercatracing.com
    I got this hull from there:
    http://forums.offshoreelectrics.com/...ad.php?t=20527
    Great guy running everything and ships from the USA
    www.keithbradleyboats.com
    • Diesel6401
      Memento Vivere
      • 4391
      Can you give a little more information like what size 1500kv motor and what are your speed expectations? At 1500kv on 4s your rpms are going to be rather low.
      Here's a thread on the r2hobbies cat: http://forums.offshoreelectrics.com/...ad.php?t=16095
      - Diesel's Youtube
      - Diesel's Fleet
      • Alexgar
        • Aug 2009
        • 3701
        bby scatcat 26
        雷速LS唯一官方网站-雷速ls官网登录入口【请收藏永久域名:tiyu9898.com,tiyu8989.com】,于2005年8月在香港实现资产上市,注册资金68.35亿元,截至2020年末,燃气年供应量369亿立方米,用户总数965万余户,运行燃气管线长度3.58万余公里,资产总额1325亿元。雷速LS唯一官方网站-雷速ls官网登录入口坚持新发展理念,坚持实施一体两翼、循环发展发展战略,以改革创新为动力,以效率效益为导向,以对接资本市场为突破口,增强企业核心竞争力,全面开创雷速LS唯一官方网站-雷速ls官网登录入口集团公司高质量发展新局面。
          A 1500 Kv motor on 4S is about what the SV27 and BJ26 came with so expect speeds in the mid/high-30s - if the motor is large enough. Assuming you have a PB or AQ motor you can have good luck with the Aeromarine Mean Machine that Steve sells, or find a used BJ26 etc. The HOTR-type cats are a bit longer than you wanted, and they are narrow so they don't turn all that well but they certainly are an option. Hull quality can be an issue with the Chinese hulls, some will never run well.
          • forescott
            Hopelessly Addicted to RC
            • 3009
            I have a Mean Machine in the swapshop I tried to sell as an artr. The one in my avatar. I had no luck so I sold the motor and speed control out of it. I would sell you the hull/hardware as-is for 200-bucks. All you would need is a motor/speed control/batteries/and flexshaft & prop. It was a brand new build only run 3-times.
            • DyrtyByrd
              • 163
              i actually just bought a used scatcat the hull was damaged in shipping and seems very thin in spots so i was thinking of a glass hull do you guys think this setup would work in the 32" fighter cat riversport maybe 2300kv 36-56-06, 100 amp esc, on 4s should be about 34000 rpms
              • keithbradley
                • 3671
                2300kv @ 4s will usually require more esc. 100A wont make it, especially if its a cheap one.
                Not sure what motors you are looking at, but keep in mind the watt rating. To power a cat that size you want AT LEAST 1500watts if you want it to run well. If those are hobbyking motors they probably arent half that, and they wont spin at that RPM once you put a prop on them.
                • DyrtyByrd
                  • 163
                  yeah the 2300 is from hobby king i bought for my rio(way too much) and the 1500 is from a blackjack i was just looking for cat i could run on the stuff i have well being that the scatcat is abs it should be lighter and maybe run on one of these setups, you think? i guess i could always glass or cf the bottom
                  • Diesel6401
                    Memento Vivere
                    • 4391
                    None of those motors will work will in a 32" JMO, like mentioned already. I don't personally know much about the scat cat, but looking at the dimensions looks like a good hull for that bj motor you have and the 100amp esc will work nicely with it. JMO
                    * Most of the HK inrunner motors just don't put out a lot of wattage at all. Most of the 36-56 series motors are only good for around 450 watts they have some decent outrunners though for good prices.
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • DyrtyByrd
                      • 163
                      yeah your right the 2300 kv is 400watts i didnt even notice but it seemed pretty powerful in my rio when it was doing full barrel rolls lol i guess the scat cat it is hopefully i can get at least a 40mph setup out of that thanks for the help guys and im still open to suggestions thanks
                      • DyrtyByrd
                        • 163
                        so deisel 6401 i noticed on another thread you posted on (geico twin revisited) you were talking about those suppo motors if i went with the 32" rivercat would a single motor system work good for this size and off the top of your head what type of speeds could you get with this setup
                        • Diesel6401
                          Memento Vivere
                          • 4391
                          The motor I referred on the twin is the same motors I run in my twin and they would be to small by themselves for that hull. JMO.... A lot of guys have had good luck with the t-600 outrunners on that hull. The Hobbycity and Fightercat motors are suppos.
                          Shes a big motor and will work well by itself if your looking for outrunners. Different sizes and kv's. Just stick with a t600 size motor and you should be fine or you can PM Ben the owner and a active OSE member and ask him what he thinks would work best.
                          - Diesel's Youtube
                          - Diesel's Fleet
