Ms Geico Twin revisited
  • JackBlack26
    • May 2007
    • 904
    I would go 4S. 2 of those motors is a lot of power for this boat. The boat becomes rather unstable close to or over 60mph. Still manageable but you want to ha e usable power. If it were me, I would go with 4s and prop up as needed. Higher RPM's will also load up your ESCs more risking possible overload failure. My Geico on 4s 2p with a 1512 2650 is almost undrivable on other than smooth water. It looks awesome but not very practical.
    • Alexgar
      • Aug 2009
      • 3701
      where can you buy the neu batteries
      • Basstronics
        • 2384
        Its a super secret...
        Give me some input I will give you the link.
        • JackBlack26
          • May 2007
          • 904
          Neu batteries can be found here.
          Those 3S 5000mah packs are a great deal! Too bad they're out of stock.
          • Basstronics
            • 2384
            Now wheres the fun in that?
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3416
              Here's some input. Id go 5s on those motors. Less amp draw and high rpm isn't a bad thing. I run 41,000rpm in my silver twin. No heat issues at all and its fast. Will you post the link for the batteries? I'm in bad need of some and wouldn't mind trying something different other than Turnigys.
              • JackBlack26
                • May 2007
                • 904
                Haha! I figured since I had given my input I could share the link...........
                Here. See what happens with an over powered Geico when you hit WOT
                • Basstronics
                  • 2384
                  Ya Im thinking 5S... Crank those RPMs up. I want to be mid 60's
                  • Basstronics
                    • 2384
                    Theres my boats previous owner doing a flip... lol
                    I might add a wing to it... Front end spoiler... lol- seriously. Make it out of clear plastic...
                    • rchuntlsl
                      • May 2010
                      • 122
                      Great idea. Go for it. I would love to see this when it is done.
                      • JackBlack26
                        • May 2007
                        • 904
                        The wing wouldn't be a bad idea if you can make it hold. I might have to copy you! Someone in the video mentioned that it caught a head wind but I was running with the wind when it happened. Headwind was heading away from the camera. A fellow boater that runs a Neu 1415 2700 kv motor flipped his the way I did mine but he busted his canopy in to pieces. I'm going to glass my canopy this week before the next time out.
                        • blackcat26
                          High Speed Junkie
                          • Sep 2009
                          • 1750
                          It does not need a wing I just had my cog too far back.
                          • Basstronics
                            • 2384
                            Right, I will try this first of course.
                            Hopefully I can shimmy the weight forward between the ESC's and packs.
                            • blackcat26
                              High Speed Junkie
                              • Sep 2009
                              • 1750
                              Yeah man you should be able to get the weight right. I was just getting to aggressive too soon!
                              • Basstronics
                                • 2384
                                Motors and water jackets came in today...
                                Motors fit well. Not to sure on the water jackets. I ordered the XL versions to get the most cooling. I think it was a mistake. It seems to fit, but the fitting will be in one ODD spot.
                                Im going to get some bolts Wednesday and get this together.
                                Pics:
