Help on bec for twin setup
  • SANTAVY1
    • 212
    Running etti race 150's no bec on 5s each side on my hpr 06' setup and would like to eliminate the 6v servo battery. Planning on using the cc bec run off one of the 5s batteries. My question is will the extra 6volts being used for servo draw the battery down much faster than the other 5s?? or is so minimal I should not worry about it?
    Any thoughts please.
  • SANTAVY1
    • 212
    THANKS FOR ALL THE HELP!!!!!!!
    • Igoreski
      • Apr 2010
      • 81
      I run a small helicopter battery for the BEC,800mah 2s so I do not cut into the time of the main battery packs.So the answer to your question is yes it matters.I have a Castle BEC in my monster truck and like how you can tweek the voltage.In my twin motor cat I use a 5a 2s BEC that you can get from hobby shops and it has a 5v-6v jumper.I now use BECs in everything because it causes less stress/heat on the ESC.
      • 785boats
        Wet Track Racing
        • 3423
        The amount of power used by the steering servo & the electronics in the ESC is negligible over a 3 or 4 minute run . You won't notice the difference between the batteries because of it.
        Cheers.
        Paul.
        • Eodman
          • 1285
          Point of interest here --- most of us have lives on weekends ! That said when you ask a question on Fridays alot of time you will not get a quick answer!
          So sit back and please stop shouting ... you my friend are not the only boater on here!
          We did it with a Bang!
          Cats Are Where It's At!
          • Igoreski
            • Apr 2010
            • 81
            I did not know you were only doing a 3 or 4 min run so I stand corrected.I switched because my left battery would hit the lvc early and shorten my run time.Also the extra heat will not matter in that short of a run.
