Instaling dual water pick ups question
  • Cooper
    • 1168
    I have a question in regards to in staling water pick-ups through the hull, I have measured and cut holes in the bottom of the cat, I have the pickups flush with bottom. Almost a perfect fit, my question is that of what glue, fiberglass, or epoxy should I be using to secure them to the hull. I am installing the aluminum dual flush mount pickups. I have placed these as far back in the hull as I could. I'm working on a ekos. I have removed the battery tray and in process of removing the glue left over from factory install, should I be using same stuff and if so what is it? Originally I was going to use zpoxy 30 minute formula, should I be using this? And is any Fiberglas needed around them or is drooping extra glue, epoxy around then good enough? And first time posting something, thanks for the opinions, have read almost all the posts in this forum and very helpful
  • LarrysDrifter
    Big Booty Daddy
    • 3416
    You already started this thread.why again?
    • Cooper
      • 1168
      Bigger range of viewers, in the general discussion area, no replys, at least none pertaining to the question asked
      • drwayne
        • 3012
        I used a half spot of CA to hold it in place, covered bottom with tape then added epoxy from inside when boat right side up..
        filled most every gap.. little gaps got a spot fill in 24hrs.
        light wet sand 600..perfect finish.
        W
