motor esc problem
  • yo man
    • 11
    motor esc problem
    Put my df 23 on the pond today for the first time.( first time with a FE boat.) It ran great thru the first battery. Waited about 15 an placed 2nd battery in. The boat ran great for several laps then died. After rescuing (ice on the pond made it difficult) I plugged in another battery. A spark blew at the connector going from the esc to the motor. I disconected that wire believing it had came unsoldered. it looked fine. plugged the battery back in an the moter barley runs an it was unballanced. The motor AMMO 2300 original esc. Could the lead be bad? ESC bad? Motor bad? any help guys
  • Diesel6401
    Memento Vivere
    • 4391
    Need a little more info. What prop did you use, what batts did you use. Temps before plug in not just wait time? Also is this the sniper you are talking about?
    - Diesel's Youtube
    - Diesel's Fleet
    • yo man
      • 11
      Factory prop. 4s 4000 mah. i didnt get to get a temp after hard running Got it stuck on some thin ice an it took a while to retrieve. changed bat an took off.
      • yo man
        • 11
        This is the df 23
        • Diesel6401
          Memento Vivere
          • 4391
          Theirs your problem... Stock esc is rated at 3s http://www.offshoreelectrics.com/pro...sc-45a&cat=150
          - Diesel's Youtube
          - Diesel's Fleet
          • Rumdog
            • 6667
            Actually, it is a 7s esc.
            • Diesel6401
              Memento Vivere
              • 4391
              WHAT?!? Are you serious? Where did you find that at? Everything I read said 3s... You know more then I do, just trying to figure out where you found that info at... 3s-7s is a VERY big jump...
              - Diesel's Youtube
              - Diesel's Fleet
              • Rumdog
                • 6667
                Yup. This was my old boat. I thought the same. Ray S told me it was a Suppo 7s 45 amp esc. I checked it out and, yup it sure was. I think the generally want people running 3s with the stock motor. Been working with yo man via PM to try to find the culprit.
                • Diesel6401
                  Memento Vivere
                  • 4391
                  So funny you said that because looking at the yellow wrapping I thought it may have been after you mentioned 7s. Since it's your old setup i well greatlfully bow out ... You can provide better info then I can on this setup... Thanks for the info on the DF esc..
                  - Diesel's Youtube
                  - Diesel's Fleet
