10S Pursuit
  • Lasse Baardseth
    • 76
    10S Pursuit
    I know this is overkill, but as a HV addict i just have to give it a try.
    The battery in the boat is just there for display as i am waiting for 40c lipo`s.
    Motor Neu 1521 1,5y (1050kv)
    ESC Etti 200A HV
    Prop Prather 230, X642 and X645
    Batt 10s 5000mAh lipo
    It turned out rather heavy ( RTR 4,15kg or 9,150 pounds) But every room is filled with flotation.
    Let me know what you think.
    Cheers Lasse
  • nobbiworld
    • 170
    Wow, Cant wait to see a video. Mine is overpowered with a 1521 1y on 6s1p. Hope you added carbon or cloth to the bottom of hull. They are weak at best. Best of luck.
    • video200
      • 840
      ser bra ut lasse :D
      cant wait to se this one in action. vid wil be good:)
      • Lasse Baardseth
        • 76
        @video200: Takk for det
        Cant wait to test, but it is winter now
        • video200
          • 840
          dont i know it. i was down the other day to check on my lake and the ice was 12cm some places. but it is getting there, another month and i intend to start ripping up the lake agian.
          the forechast dont look to good for you guys this weekend. as low as -11c that wont help to get ridd of the ice.
          bare hyggelig :D
            • 7512
            Almost 40,000 rpm......motor won't last long....should be fun for a few minutes though...
            • Lasse Baardseth
              • 76
              NEU 1521 1,5y is ratet for 60K max rpm and 57volt max.
              I dont see why 40000 rpm for a short time will be a problem?
              • Make-a-Wake
                FE Rules!
                • 6057
                It wont be................
                  • 7512
                  OK.......
                  • AlanN
                    • Mar 2008
                    • 334
                    Why do you think it won't be a problem?
                    • Make-a-Wake
                      FE Rules!
                      • 6057
                      Because it's rated to 60k rpm's and will be running in the 35-37,000 range under load.................. He doesnt need to go gonzo on the prop though, starting smaller. Its a bit high but should be fine.
                      • Rumdog
                        • 6667
                        That motor cab and will handle that rpm. Keep the prop size down, and check temps. It should be just fine.
                        • AlanN
                          • Mar 2008
                          • 334
                          I understand (not that I necessarily agree) your rational but do you also think that the controller will keep up with that rpm?
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            The controller doesnt care at all what rpms the motor is running....it only supplies the voltage.
                            • wparsons
                              • 461
                              ^^ Not 100% true, the ESC has to be able to handle switching fast enough to keep up as well. Depending on the number of poles and the ESC, it might be faster than the ESC can handle.
                              Light travels faster than sound, so people may appear to be bright until you hear them speak.
