Twin drag cat
  • dasboata
    replied
    Boat is for sale I am buying a mystic C5000 yup I know I am listing to you guys thanks chris
    Leave a comment:
    replied
    Originally posted by Punisher 67 View Post
    Not a problem Chris
    Here is a single 1717 mount , the Castles are a little more difficult because of the wires at the rear
    I install a double O- ring buffer at the rear
    hmmmm
    Leave a comment:
  • dasboata
    replied
    I am interested in that guys Mystic C5000 I wrote him like 6-7 times and no responce
    Leave a comment:
  • dasboata
    replied
    Originally posted by rearwheelin
    I just wanted to let you know that if you would like a custom double motor mount that I am more than happy to meet your gole with you...By no means am I trying to take away from P.Z.. I posted early in your thread but whent un answered....Just wanted you to see some custum mounts I did....For 2028's I would make a 8mm thick motor plate.......... Sky is the limmit ! $250.00
    Yes I saw thank you !! that is something I can make for myself if I wanted to go that root thanks chris
    Leave a comment:
  • Punisher 67
    replied
    Not a problem Chris
    Leave a comment:
  • dasboata
    replied
    Hello Chris
    I am Peter Z..........Why don't you draw up what you had in mind , I also don't work with CF , One day maybe
    Sorry Peter My mind is blown too much going on can you tell me how the rear of the motor is secured ?
    Leave a comment:
  • Punisher 67
    replied
    Hello Chris
    Leave a comment:
  • dasboata
    replied
    I like the mounts BUT there is alot of extra material there you can probleby reduce the size and cut the weight in half also on the alum tubes you might want to concider CF for that WOW effect that's what I would do to mine I already have e mailed Peter Let me see what happens PM me a ball park price I don't need the alum tubs and I would want them reduced down quite a bit what do you think thanks chris
    Leave a comment:
  • Punisher 67
    replied
    That mount would bolt to a set of 6" rails , you don't see them in the picture but it would have two mount holes on each end as to be bolted to a stringer system , I have yet to see anyone use rubber isolators for electrics
    Leave a comment:
  • dasboata
    replied
    This dual motor schematic was done by Racemechanix on our forum here , me and Tyler have worked on some joint projects , this is Seedoobobs mount
    now nobody get to excited this has yet to be milled , I should have the run written today and will run it sometime next week............
    Nice mount !! I would prefer something I could mount to the rails do you guys ever use rubbers Isolators to mount you motors ??
    Leave a comment:
  • Punisher 67
    replied
    Leave a comment:
  • Punisher 67
    replied
    Yup I would consider a bigger hull , a lot bigger...................
    Leave a comment:
  • blizard05
    replied
    Come on Chris,don't give up,you and I both know the DC can do 80+ Wally did it with gas. Go ahead and womp him with an electric set up.
    Leave a comment:
  • dasboata
    replied
    Originally posted by seedoobob3 View Post
    Hey Chris, Peter is building my twin mount side by side 1717's now, set my rails to 6" to get both centered betwwen rails, straight out stuffing tubes to twin inline strut/rudders from aeroM, he does a great job.
    I e mailed him I not sure I am going to go threw with this hull I have been told it is way to small
    Leave a comment:
  • seedoobob3
    replied
    Leave a comment:
