stopping chine walk
  • Gen
    • Dec 2010
    • 130
    stopping chine walk
    is there any fixes for chine walk ,
    now i have taken my UL1 hydro out a few times and played with different props 40,52,3 and 40,57,3 and m445 ,it has a side really bad port to starboard rock going on (up and down)
    i have played with strut angle ,height and turn fin with not much success of reducing ,
    and i have sanded my sponsons flat .. ,and props are super sharp and balanced
    any help please ..
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    The AoA (angle of attack) on the UL-1 sponsons are too aggressive in stock form ; likely designed that way to allow for looser running/more speed when run as a stock RtR. Once "pepped up", the boat rides up & down on this, causing the chine dance. By reducing the AoA, this can be mostly eliminated. I made wedged ride pads with birch ply - having a belt sander helps, and boat can now run 49-50 mph without the "death dance".
    • LiPo Power
      DJI Drone Advanced Pilot
      • 3678
      Is it stock motor and ESC?
      Canada
      • ncornacchi
        • Jul 2009
        • 256
        Straight turn fin also helped me out....Kintec sells nice ones
        • Gen
          • Dec 2010
          • 130
          yes stock motor ,i might try changeing the AoA and putting ride pads in like mr propper chopper will let u know how it goes
          how thick are yours at front in mm (as im in australia) 5mm ??
          • Diesel6401
            Memento Vivere
            • 4391
            http://forums.offshoreelectrics.com/...ead.php?t=8304
            - Diesel's Youtube
            - Diesel's Fleet
            • Jimboat
              • May 2010
              • 5
              chine walk
              here is an article on chine walk for big boats. principles are all same for RC's.
              /Jimboat
              AeroMarine Research
              'Secrets of Tunnel Boat Design' book
              • detox
                • 2357
                This mod will help your UL-1 be a little more stable in rough water, but if you are getting sponson hop down the straits in calm water, then sponson angle is not your problem.
                My modified UL-1 will chine walk if I use a prop that is too large or too much pitch. The m440, x442, "thinned" GR L40x57 3, works good on my hull. I am thinking the m445 may work, but may be too aggressive without changing strut settings.
                Raptor347 has a way of making larger (m445) and more aggressive props work on the UL1. You may want to ask him.
