New Hull from HK
    • 9438
    Read closely, description says motor mount for 36mm motor, not 40mm.
    They also changed the rudder from a dual intake rudder to a less expensive single and take another feed from the transom.
    • b.mcdaniel.2009
      • 1641
      Originally posted by Diesel6401 View Post
      I don't know yet. If I ran 5s I think I could get by with a seaking 180 or a swordfish 200, but I know I am going to want to run 6s every once and a while. If I ran mostly 6s I would get a swordfish 240. Not sure what I want to do. I don't want to rely on the seaking 180 or sf200 for 6s all the time, but the jump to the HV is pretty big in price.
      Ran my T-180 on 6s more than i did on 5s with no issue's at all.
      [QUOTE=ray schrauwen;281905]Read closely, description says motor mount for 36mm motor, not 40mm.
      He'll only need a 40mm Tail ring...The mount will accommodate a 4082 in lenth and as well as motor's screw mount.
      ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
      • scoota
        FE DOWN UNDER
        • Dec 2008
        • 409
        Got the email this morning, looks good. Thinking about pulling the trigger on this thing. I want to use a 4082 1450kv on 5s & 6s. Anyone think that motor in this hull will work? Hoping I can get buy with 5s1p or 6s1p, goal is mid 40mph.
        Here is one with a 5692 1340kv on 6s http://www.youtube.com/watch?v=v-dnf...layer_embedded
        UL1- 1515 castle/neu / 240 swordfish
        SV27- with UL1 running gear
        33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
          • 5554
          I run my T180's on 6s with the bec............one with a Neu1527 and one with the 1717.................never one problem. Probably have 50 runs on the Neu setup and 20 on the 1717............i may be one of the "lucky" ones, but i dont see a problem doing it personally.
          To each his own..........
          • Diesel6401
            Memento Vivere
            • 4203
            That's why God made Zip-ties lol...
            Only the support ring is different and I think I have a extra 40mm laying around so it won't be an issue.
            * Interesting on the T-180's. I just never was a fan of pushing the esc's to thier voltage limits though. Would save A LOT of money though. I may run the T-180 on 5s mostlt and throw in 6s for some speed runs. Would be nice to save that extra cash and not need a HV esc. Thank's for all the advice.
            - Diesel's Youtube
            - Diesel's Fleet
            • b.mcdaniel.2009
              • 1641
              I think i have one laying around...I'll check.....
              • Diesel6401
                Memento Vivere
                • 4203
                Cool....
                - Diesel's Youtube
                - Diesel's Fleet
                  • 9479
                  Very cool and the price!
                  • b.mcdaniel.2009
                    • 1641
                    Cool....
                    Cant find the dang thing, but i know i have one somewhere lol.....
                      • 9438
                      I could use a 36mm one....
                      • b.mcdaniel.2009
                        • 1641
                        That i have and know where it is.... LOL.......
                          • 9438
                          Do you want to part with it or is it in use?
                          • b.mcdaniel.2009
                            • 1641
                            Just sitting in my tool box......I take it ON isn't in the u.s....
                              • 9438
                              Nope, Canada....
                              Shouldn't be much in a 4x6 padded envelope... Let me know...
                              • martin
                                • 2869
                                I have one of the 41" Osprey hulls which is the same hull, I was also looking at putting a Leopard 4082 1500kv on 6s. Would i get away with a T 180 esc or a Swordfish 200, Which would be the best choice between these 2 esc. Also what props would work well on this set up. Thanks Martin.
