NEU 2215 motor Q
  • don ferrette
    • 1252
    NEU 2215 motor Q
    In need of some info- on the NEU smooth case 2215 need to know the diameter and usable case length for a possible custom cooling jacket. The OSE cooling jacket diameter for the finned case is 3" which is a bit too large.
    - IMPBA Hall of Fame -
    - IMPBA Hydro Technical Director -
  • drwayne
    • 3012
    -68mm dia.
    -95mm OAL
    -720gm
    W
    • Make-a-Wake
      FE Rules!
      • 6057
      I'm coming up with 63mm dia. x 84mm length
      • RaceMechaniX
        • 3024
        Don,
        I measure 57.5mm or 2.264" diameter on my motor and a useable length of 2.1"
        Neu's sites list 57.413mm for a smooth can.
        Tyler
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
          Looks like the Leopard Cooler comes very close....
            Nope...
            You could just buy 2.5" Aluminum tubing with .0625" wall and just silicone it on or try for the 1/16" orings instead of the 3/32" orings I use for my Leopard 56mm can. I think it will work... I'll crunch numbers....
              O.k. a piece of 2.5" tubing minus .125" total (.0625 x2) wall = 2.375" ID
              a 2215 with proper sized .0625" cross section Oring on it is approx. 2.389" total OD.
              2.389" - 2.375" = 0.014" or .007" compression per sideof oring. This can work.
