Need Instructions for this ESC
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    Here is the ESC:
    Thank You for help....
    Robert
    Canada
  • Alexgar
    • Aug 2009
    • 3701
    • carlcisneros
      • Jan 2010
      • 1237
      hey LiPo go over to the boat building thread section, open it up, cursor down to the
      33" mono copy/clone subject, open it up, then cursor down towards the bottom of the
      cells and you will see my posting and there you will find all the Suppo programming
      instructions for the ESC you have.
      Suppo changes things from time to time (when ever they feel like it) and do not pass that
      info along to the customers.
      program it using a 3S pack (to keep the heat down during programming!!!!!!!!)
      when you are finished with the last step of programming, PUSH the throttle trigger all the way forward until you hear the final sinlge long beep. you are done.
      run them around 150-160 MAX amps. They warm up pretty dang good if pushed hard. they are a multi
      circuit board lay up and the only board that gets water cooled is the top board.
      If using 5-6S packs, use an anti spark lead to pre charge the capacitors before plugging in the packs to the main leads.
      If you follow these little tips, it will last you quite a good long time.
      Carl
      • sailr
        • 7128
        The only 200 at Astec is the HV, not this one.
        Mini Cat Racing USA
        www.minicatracingusa.com
        • LiPo Power
          • 3678
          I got it, thanks for your help.
          One question.. What is the defoult set up on them?
          I will run this ESC on 4S2P and Neu 1521, 1.5D, 33 DF.
          Thanks
          Robert
          Carl
          Canada
          • carlcisneros
            • Jan 2010
            • 1237
            LiPo
            take a look at the links in my other posting and it should show defaults by the * symbol.
            It is set for NiMhd batteries tho as default.
            Carl
            • LiPo Power
              • 3678
              So there is no PC way of programming this ESC?
              I hate stick programming, it's so confusing.......
              Robert
              Canada
