best esc for leopard 4074 2200kv?
  • dana
    • Mar 2010
    • 3660
    for Mean Machine, running 4s2p and probly m545 prop. im looking for something in the 100 dollar range with reliable bec, some sort of low voltage warning , and super easy set-up. i like my ul-1 set-up cause they're soooo easy. T180 or do i need a 200 amp esc? thanks, Dana
  • Alexgar
    • Aug 2009
    • 3701
    i run a t180 om my cc1515 2200 on a 42 prop and the esc comes in cool the motor runs alittle warm but i cant fit a coole in my appirition cat due to space limitations
    • dana
      • Mar 2010
      • 3660
      the seaking is the same as the turnigy? just different name?
      • dana
        • Mar 2010
        • 3660
        oh and thanks for the freind request
        • marko500
          • 862
          I have a PT Stealth hydro and a Bittburger cat both running the Leopard 4074 2200kv and the T180 esc. No problems and both run nice and cool. They seem to be a pretty good combo so far.
          Mark
          • marko500
            • 862
            I believe the Seaking and the Turnigy 180s are the same.
            Mark
            • steveo
              • 1595
              put a feeler out see if anybody has one there lookin to sell
              • Alexgar
                • Aug 2009
                • 3701
                same and use the same prog card atleast but i hear v2 is the one to have ive had both and dont see the differance
                • Alexgar
                  • Aug 2009
                  • 3701
                  i have the same setup on a etti 150 2-7s w etti caps and great results as well just another option i have a swordfish but that might tax its limits as it puffed a 5000 20c
                  • Rumdog
                    • 6667
                    "THE BEST" esc for that setup would be a Castle 240lv. The T-180 will work good as well. I'd still use a R/X pack though.
                    • dana
                      • Mar 2010
                      • 3660
                      well im on a bit of a budget..? unless you got a240 you want to sell me for 100 bucks lol
                      • dana
                        • Mar 2010
                        • 3660
                        im curious do i need program card for seaking 180? what are the advantages to having one?
                        • Alexgar
                          • Aug 2009
                          • 3701
                          easier but programing is a cinch on these a waste of money as far as im i think they said the swordfish shouldnt be programmed by tx but if you know one you know them all bbep beep just read and listen, i actuallt have a manual i can dig up if you want to see it but here it is off hk
                          all the same for turnigy
                          http://www.hobbyking.com/hobbyking/s...7X76598X56.pdf
                          • Alexgar
                            • Aug 2009
                            • 3701
                            as much as i like my swory 120 i might try the 200
                            • dana
                              • Mar 2010
                              • 3660
                              ok thats a little bit confusing lol. im sure its easy but theres alot of info there
