steve, or anyone, what motor mount?
  • dreamland s4
    • Dec 2010
    • 347
    im so hooked on this forum, anyways guys i need a motor mount from ose, heres the motor thats going on a proboat 1/8 hydroplane. (keep that in mind) mucho thanks! leopardmax amps: 78alipo cell: 5-10smax power: 5500wkv(rpm/volt:1000kvresistance: 0.0073non-load current (7.4v): 3A heres the link just in case http://www.hobbypartz.com/77p-lbp5692-4d-1000kv.html
    If the #2 pencil is the most popular, why is it still #2?
  • Fruity
    • Jan 2009
    • 189
    Dreamland, same motor here from Steve @ OSE = http://www.offshoreelectrics.com/pro...o-5692&cat=148
    There's no mount listed for that big baby on the OSE store, i suggest you would need to mage one from fome flat aluminium to suit your hull.
    Cheers...Tim.
    • dreamland s4
      • Dec 2010
      • 347
      Cheers...Tim.
      tim thanks alot!! yea i noticed there wasnt any :/
      anyways i have a foot long aluminum L-bracket. its time to do some work hee hee
      • RayR
        @SiestaKey.calm
        • 1591
        Go Here: http://forums.offshoreelectrics.com/...ad.php?t=10698
        Peter's work is fantastic.
        Ray
        • dreamland s4
          • Dec 2010
          • 347
          Ray
          un friggin believable thank youuuuu
          • sailr
            • 7128
            Peter made two mounts for my 5692. One for hydro/cat and other for deep vee.
            Ray
            Mini Cat Racing USA
            www.minicatracingusa.com
            • dreamland s4
              • Dec 2010
              • 347
              ok, heres my problem, i have a proboat 1/8 hydroplane, what kind of info am i suppose to give peter in order to insure i get the right mount? would u or anyone be able to give me the info i need to give peter regarding the mount i need?
              • Rumdog
                • 6667
                PM him. He will ask you the questions. Generally, rail width, and motor diameter/length and endbell type.
                • sailr
                  • 7128
                  IF your proboat has rails in it. Otherwise, it just bolts through the bottom of the boat. That is what I mean by a hydro/cat type mount. He already knows the dimensions, etc. for the Leopard 5692.
                  Mini Cat Racing USA
                  • dreamland s4
                    • Dec 2010
                    • 347
                    well i mean yea it has the rails where the stock gas motor was mounted to. so i would need to measure the distance between both rails? and of course tell him the motor i have? (leopard 5692) and thats it?
                    • sailr
                      • 7128
                      Yep. Your rails are probably 5" spacing but you need to measure to be sure. If you wish, you can also ignore the rails and bolt the mount through the bottom of the boat.
                      Mini Cat Racing USA
                      • dreamland s4
                        • Dec 2010
                        • 347
                        no way i think if i bolt them to the bottom of the boat it expose the screws where the boat rides on the water. this is the measurement between the inside of the rails
                        • Rumdog
                          • 6667
                          It's a hydroplane, so the tunnel isnt riding on the water. However, i still wouldn't do it. The tunnel floor is much too flimsy. I have a 1/8 Elam that I ran with a 2215 on 9s2p. I made my own aluminum rail mount.
                          • dreamland s4
                            • Dec 2010
                            • 347
                            flimsy is right! im planning to lay some carbon fiber inside the bay. i really cant stand how they price that thing with a zeno motor (not that there bad or anything) for 999.99
                            anyways i think peter should be able to work with that measurement right? or?
                            • LarrysDrifter
                              Big Booty Daddy
                              • 3416
                              Pm Pete and he will get all the required information from you that he will need to build your mount.If you dont understand something he wants,tell him and he will explain it to you.None of us can answer your questions about what Pete may want.He is a very nice person,just ask him.He will be glad to help you.
