Hello Chris,
just a few recommendations from my point of view: For going 100mph I wouldn't rely on common FE speed calculators. They might be quite accurate for lower speeds but for 100mph I think the difference is just way to big.
And for size/width: It all depends on the hull, you can also run very fast with short and quite wide hull. This means aero- as well as hydrodynamic as well as the right setup and correct CG and trimming. You can even achieve stable 100+mph at SAW with a 35" cat hull (thats shorter than a Genesis)
But I have to say that I have as far as I remember never seen a single engine cat running close to 100mph at an SAW event. It might be possible but very very difficult. Therefore I'd try it with two engines.
For Norberts HPR 135: I have seen it running at Ertingen and its an amazing machine but be aware that they have really plenty of knowledge for going so fast.
I don't know your hull and if its capable of these speeds. As said blow-overs at these speeds are just horror. So lets say your hull is strong enough and capable to handle these speeds, you might want to go for a twin-Scorpion Setup with 2x 12S Lipo and Octura X457 props.
Best regards,
Manuel
Best regards,
Manuel
