battery tray?
  • Bigbore
    • 179
    battery tray?
    I'm going to move the battery more rear on my Titan 29" because it runs a little wet.
    I have ordered two wooden battery trays from ebay that are the same that I have glued on the bottom of the hull.
    http://cgi.ebay.it/ws/eBayISAPI.dll?...=STRK:MEWNX:IT
    While waiting to be here I have decided to build two trays a little longer and made of carbon.
    The two ordered are 130mm lenght and the ones I'm building are 200mm.
    What are the most used battery trays?
  • LarrysDrifter
    Big Booty Daddy
    • 3416
    Velcro.
    • Flying Scotsman
      Fast Electric Adict!
      • 5195
      Now that is a Douggie answer
      Douggie
      • Diesel6401
        Memento Vivere
        • 4391
        Originally posted by LarrysDrifter View Post
        Velcro.
        +1
        I normally remove them if the boat comes with them or I use them for other stuff. I used the stock battery tray on my Pursuit to mount my esc and gps to it.
        - Diesel's Youtube
        - Diesel's Fleet
        • LarrysDrifter
          Big Booty Daddy
          • 3416
          Douggie
          Hope I made you proud.
          • Bigbore
            • 179
            With the batteries I've been using (700 gr each) only the velcro can't hold them in case of a crash.
            I'm going to use velcro on battery tray and battery straps.
            • Make-a-Wake
              FE Rules!
              • 6057
              I use "industrial strength" velcro that comes in a 25 foot roll........its about as wide as a lipo.........a tad wider, but whe the full length of the batt has velcro, and a matching size piece in the hull, i can barely pull it out...........its in there!!
              • ozboater
                • May 2007
                • 419
                i like these..
                http://cgi.ebay.com/3Racing-AX10-20-...item1c03014d79
                • forescott
                  Hopelessly Addicted to RC
                  • 3009
                  I like velcro in a mono, but it doesn't work too well in the stepped hulls. I like to epoxy a 2" wide piece of aluminum or thin ply. and attach velcro to that to smooth out the steps!
                  • Alexgar
                    • Aug 2009
                    • 3701
                    i use the industrial to but at the fabric store its 15$ per yard for both sides
                    • properchopper
                      rcgoatbuild@snotmail.com
                      • 7708
                      Try this :
                      Make a box, epoxy it to the bottom of the hull & there you go.
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        That sure is a sturdy looking tray and lid there propper................nice, clean look too.
                        • properchopper
                          • 7708
                          Thanks ! In this case the motor-mount rails are just the perfect size to extend into a battery-holding box. Even without rails, the same concept can be used.
                          Easy in/out, and no pesky velcro flapper-strappers !!
                          I've learned the hard way that the more time spent building on the bench, the less trouble on the water. That, and the memory of a fellow club member a few SAW's ago flipping his boat, launching his batteries up and out with a CC 240 STILL ATTACHED, sending batteries and CC 240 to the bottom !
                          • Bigbore
                            • 179
                            Your solution is the best I've seen so far but in my Titan 29 the motor is located forward and I need to place the batteries on both sides.
                            Also I agree 100% with your statement "I've learned the hard way that the more time spent building on the bench, the less trouble on the water. "
                            Here is my own made battery tray. I have made two of these.
                            • ozboater
                              • May 2007
                              • 419
                              very nice bigbore... how did you get the cut outs done ?? looks super clean..
                              i purchased three of the ones i linked to from integy... my batts are on the side as well... gonna have two full trays on each side as well as a half on each side... 1.5 total per side so i can shift batts for the COG..
