Feigao motor shaft? no flat spot
  • 6sHyper
    <<<Surfs up!
    • 640
    Just wondering if any of you guys are making a flat spot or anything on the motor shaft of the Feigaos as i just got one to try and its the first motor shaft ive ever had that didnt have a flat spot for the set screws. I would imagine its only a matter of time before i'm stuck in the middle of the lake spinning the motor.
  • Make-a-Wake
    FE Rules!
    • 6057
    Grind a flat spot where you need it with a dremel.
    • martin
      • 2881
      If you dont have a Dremel you can also use a diamond file as well, Seal the motors openings as well otherwise you get metal filings in side the motor atatched to the magnets. Thanks Martin.
      • sandiegobrushless
        • 4
        I vote dremel as well, be sure to lock shaft with needle nose vise grips, & yes be very careful not to get the metal dust on the bearings or inside the motor! Cut bits of t-shirt or similar cloth to protect shaft from vise grips & seal out metal dust. Dremel bit no. 9901 is good for this application.
        Hmmm...
        • sundog
          Platinum Card Member
          • Feb 2009
          • 940
          I always put the motor in a ziplock baggie and poke the shaft through the bottom. Keeps metal dust out while you grind the flat. It doesn't need to be much of a flat - I've seen lots that have had much more removed than necessary.
          Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
          • lectriglide
            • 540
            • Make-a-Wake
              FE Rules!
              • 6057
              Great idea.............been using hatch tape to tape off the motor "holes"
              • Seadweller
                • 89
                Like Sundog's suggestions. I spun a coupler off of a Feigao then filed a flat.
                SV-27, Challenger 31, Mini-Cat ECO, Mini-xXx,
                • Alexgar
                  • Aug 2009
                  • 3701
                  i like the ziploc idea i also use tape and a dremel tool
