EP1 propeller shaft!
  • Eodman
    • 1285
    Well we dropped our Cat over the weekend and bent the propeller shaft on at least one of the units!
    Now are you ready for this ---- acccording to great planes product support the shaft isn't available seperately! In the exploded view found in the owners manual it has an item # assigned to but no Part# !!!!!!!!!!
    Only way to get it is buy a new EP1 Now doesn't this suck!!!!!!!
    We did it with a Bang!
    Cats Are Where It's At!
  • kck741
    • 282
    Thats crazy !! May I ask how you bent the shaft
    S.S.R.C-Southern Style Radio Control
    • Eodman
      • 1285
      Yes getting xmas decorations out of the rafters & someone was in a hurry to get to a basketball game!!!!! Knocked it off the workbench!!!!!
      • RCprince
        • Jul 2007
        • 1684
        I've had 3 ep-1's and all fell and bent their shafts so I had to make some out of of rods from the LHS I believe 3mm or 4mm anyway I had to put a die on it to get the threads, worked great then I upgraded to a 3/16 shaft the ocutra one i think it's the 4mm to 3/16th kit. GP is lousy when I comes to that EP1 first the brass gears are a poor design for any serious power and replacement parts...otherwise they would of had a killer product. I bought sets of gears from steve already....
        Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
        • GregS
          • 82
          I bent the propshaft on mine simply by tightening the prop nut a bit too hard. I bent it back to as straight as I could get it. The prop shaft does bend easily.
          Greg
          • Steven Vaccaro
            Administrator
            • 8934
            Its the unfortunate part of owning these. But the shafts are usually not the problem. The gears are, and we have an aftermarket source for those.
            Steven Vaccaro
            • RCminded
              • 3
              What is the source for aftermarket gears I have had one with stripped gears for like a year.
              • Steven Vaccaro
                Administrator
                • 8934
                http://www.offshoreelectrics.com/products.php?cat=48
                Steven Vaccaro
                • RCminded
                  • 3
                  What are these made out of? Hopefully not brass but anything is better than nothing! I put brushless in mine and toasted the original gears. I called aquacraft and the sent me a whole new motor free! so that one has remained brushed, so far.
