How much water is too much
  • roadrashracing
    • 1630
    I have a water problem and can seem to solve it, it is all during tube test. I let it sit for about a half hour and the when I com back there is a little bit of water. I've sealed it the best I could, I've even hot glue the screws on the inside.
  • LarrysDrifter
    Big Booty Daddy
    • 3416
    Dont walk away from the water test.Stay there so you can see where its coming from.Instead of using hot glue,get some clear silicone from the parts store.It seals a lot better.
    • soliverg
      • Jan 2009
      • 45
      depends on what boat hull you have. some like the older sv 27's have a transom backplate which will leak unless its sealed from the outside.
      cheers
      • HYDROJERRY
        • Jan 2010
        • 2709
        I second the clear silicone,,,,you dont want to glue in your bolts, if you have to remove them they could damage the hull in the prossess clear silicone wont,,plus the silicone will spread into the tinny areas like the threads and any little cracks or gaps...
        • roadrashracing
          • 1630
          I'll try that next time I have it apart
          • Brushlessracev
            • Oct 2010
            • 154
            I used thread sealer on the threads of the screws, can get it at the auto parts store. its used to seal chevy head bolts.
            • H2OCamel
              FAST ELECTRIC EVERYTHING
              • 494
              I have never had a problem using silicon, best part is being able to remove the parts when you need to.
              "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
              • roadrashracing
                • 1630
                Thanks for the tips, the hull is now dry.
                • jac4412
                  FE Addict
                  • Jun 2010
                  • 427
                  road, just an fyi, depending on the hot glue placement and how hot your inside of the hull will get... you can get the glue to re-melt in your hull... in my early hobby days I thought hot glue was the way to go, just to find parts everywhere halfway into my run. Even a little heat can get that glue to soften
                  JAC4412 RC
