Marine MHZ-Scorpion 5035/760 (2136/W)
  • oscarel
    • Dec 2009
    • 2373
    Now what could a person do with this?
    Special version of Scorpion MHZ-HK-5035 with 760 Upm per volt, specially for boats.
    Engine has specially large ballbearings, 10 mm shaft and integrated water cooling.
    Specifications
    Outside Diameter 61,0 mm (2,4 in)
    Stator Diameter 50 mm (1.96 in)
    Stator Thickness 35 mm (1.37 in)
    Magnet Poles 8
    Motor Kv 760KV RPM / Volt
    Max Continuous Power 5800 Watts
    Max Continuous Current 150 Amps
    Weight 729 Grams (23,43 oz)
    Shaft Diameter 9,98 mm (0.393 in)
    Body Length 75,0 mm (2.91 in)
    Overall Shaft Length 100,7 mm (3,97 in)
    Max Lipo Cell 10s
    Maximal peak power 8100 Watts
  • Ub Hauled
    • 3051
    Loads of power, can't find it here in the US though, I fired an email to Lucien and let's see what he has to say.
    • RIPFENCE
      • Sep 2009
      • 1577
      i asked lucien about these a long while ago and he said they could be ordered
      "FE" STANDS FOR FRUSTRATING EXPLOSIONS
      • tharmer
        • 342
        Sounds perfect for the 1/7 scale guys.
        T
        • Ub Hauled
          • 3051
          Did you happen to ask about price, how quick the order would be in or different Kv models?
          T
          In deed...
          • Alexgar
            • Aug 2009
            • 3701
            look at those 2028 castles im drooling
            • sailr
              • 7128
              What does an R/C car have to do with this thread? That's where you link leads to. You say CASTLE on Hobbyking? Huh? Search for 2028 and all you get is one tiny outrunner and for Castle and there is no result.
              http://www.hobbycity.com/hobbyking/s...dProduct=16241
              Mini Cat Racing USA
              www.minicatracingusa.com
              • sailr
                • 7128
                I just got a reply from Lucien. Here is what he said:
                "I have not seen that motor before. Scorpion must have made it special for them. I can check and see if they are available over here and let you know."
                Mini Cat Racing USA
                • Ub Hauled
                  • 3051
                  Jim, that's the same answer I got...
                  hopefully he can get us some info on that...
                  • sailr
                    • 7128
                    Got this today from Lucien:
                    Jim,
                    I got a reply back from Scorpion today. Those big watercooled motors are made exclusively for MHZ, and I cannot get them.
                    Sorry about that!
                    Lucien Miller
                    Innov8tive Designs, Inc
                    Mini Cat Racing USA
                      Only in Germany? Pity...
                        Ray, you can certainly order one from MHZ, they'll take your money.
                          I know but, what is that going to cost landed in Canada?
                          It's a beauty though!!
                          How long before some Duff puts 2 or 3 on ebay...? for like $600....
                          • Mel279
                            • Dec 2008
                            • 873
                            hi
                            are these motor suitable for twin cat 53"(135)?anyone knows the bolt pattern?
                            regards
                            Mel
