CF hull question???
  • LarrysDrifter
    Big Booty Daddy
    • 3416
    I think if a guy was to run a Spektrum MR3000 with the dual antennas,it should be fine.One wire gets put in a tube anyway.
    Im building the same hull but in FG myself and going to put in 3 Align outrunners on 6s each.I know it will be heavy,but I dont care.It ll probably just end up being a SAW boat anyway.My silver twin cat probably weighs about 8-10lbs.Same as the EKOS it replaced.Weight can be your friend.
    • b.mcdaniel.2009
      • 1872
      Thats what im saying. My DF 40" mono stayed planted in the water from the weight of a 2215 and 4 5s packs.....
      ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
      • b.mcdaniel.2009
        • 1872
        Originally posted by Flying Scotsman View Post
        What RX?
        Douggie
        MR3000 or i have some sr3000, and some sr3300......
        • Flying Scotsman
          Fast Electric Adict!
          • 5195
          MR labelled are great....do not use the others in that hull...my 2 cents
          Douggie
          • b.mcdaniel.2009
            • 1872
            Douggie
            Thanks for the info....
            • LarrysDrifter
              Big Booty Daddy
              • 3416
              My friend ran those surface recievers in his boat,and got crappy range and it always cut out.Stick to the Mr.3000.Ole Reliable.
              • keithbradley
                • 3671
                My 40" DF ran well with a 2215 on 10s2p as well, but my smiths cat was a different story. It wouldnt pull the sponsons up out of the water and plane out until maybe 35-40mph...or it would pull one side up and dart one way. Thats a little bit smaller hull than yours, and a very aggressive hull design so yours may be ok, I dont know. Alot of times boats handle worse with more weight, contrary to popular belief.
                Either way, it may run great in a straight line, I dont know (It more than likely wont corner as well as it would if it were lighter, but if you just want straight speed I imagine you dont care). It would be just as fast if not faster with the motors I linked though.JMHO.
                www.keithbradleyboats.com
