How to install thrust bearing on NEU??
  • txboatpilot
    • 1805
    I just got some 5mm thrust bearings for 2 NEU 1515 motors, my question is how to install them? When I put it on the motor shaft and slide the coupler on there is 1-2mm of distance inbetween the thrust bearing and the coupler?? Do you just use some sort of shims? Any one with pictures or suggestions?
    Thanks, Rich...
    Nothing like keeping you lipos warm and your prop wet!!
  • Rex R
    • 1007
    well one could trim the motor shaft...but to answer your Q yes a 'shim' will work. I've been making 'thrust plates' out of 1/16" Al plate(iirc roughly 0.75" x 1.25").
    • ED66677
      • 1300
      wouldn't a bunch of washers do it?
      Emmanuel
      • Steven Vaccaro
        Administrator
        • 8932
        The right way to do it is to cut the shaft like Rex suggested, but remember that may reduce the value of the motor if you want to sell it in the future?
        Steven Vaccaro
        • txboatpilot
          • 1805
          Thanks guy's! I am not getting rid of them! I will cut the shaft Steve....And 1 more thing Steve.. "Thanks for the help & FAST shipping!!)
          Rich
          • Avanti
            • 1298
            txboatpilot --- did you take any pics you could share with us when you did this mod, also have you noticed a difference IE: temps, power, anything??
            Thanks
            The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
            • txboatpilot
              • 1805
              I cut 2-3mm off the shaft, it wan't to help with temps and power. I installed it to keep the motor's bearings from taking the load! I will try to post a few pict's later today.
              • Avanti
                • 1298
                So the basic purpose is to reduce stress on the motor?
                Thanks I am thinking of adding one of these to my order after Christmas.
                • Rex R
                  • 1007
                  taking the thrust load off the motor bearings should let them run cooler, and reduce the overall motor temps.
                  • Darin Jordan
                    • 9446
                    While all that is true... the main reason I run a thrust bearing between the coupler and motor is to keep from pushing the forward endbell off the motor!! The only thing keeping it on is silicone!
                    All my new Neu motors are getting screws installed in them from the factory (Thanks to Brian... )... but I'll still continue to use thrust washers... Just makes sense...
                    Darin E. Jordan - Renton, WA
