T180 Killer?
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    Originally posted by iamandrew View Post
    http://www.hobbyking.com/hobbyking/s...dProduct=15134
    200AMP water cooled....
    No BEC....
    but $40 ?!?!?!?!?!
    How about $38?
    Just for my OSE buds.
    I bought a batch of 30 that are shipping soon.
    • kjohnsiii
      • Oct 2010
      • 121
      I have the supo 200 form fightercat and first run with it it got up to 190. Planning on adding a cap on it now. We will see how long it lasts, running it on a 4047 4s x642 in a miss g. So far got it up to 52 mph. Now working on getting it to stop blowing over...
      • Alexgar
        • Aug 2009
        • 3701
        125s are solid own 2 with bec
        • maxmekker
          • 466
          how do you set one up , transmitter ore by card, what are defaults out of boxs. ?
          Drammen rock City
          • GP73
            • 546
            With lots and lots of patience...
            • JMSCARD
              • Mar 2010
              • 4174
              The himodel 200 is actually super easy to set up... It's basically plug and play... Auto sets the timing.... They seem to work great unless you push em to up close to their rating... I personally would use this esc with 540xl's, and low kv 1515 and smaller neu's as well as leopards, and the like.... I ran one in a df33 with a 1521 1y.... Didn't line the amp spikes cornering hard... Poof... Did no damage to hull or motor so was only out $50.... A cheap day at the lake:) good esc for the money...
              • GP73
                • 546
                I would only buy the ones from Fightercat, with the added cooling plates in between.
                In fact I bought 2 already.
                Just my $0.02
                PS: No, I don't get paid by him for advertisment... But I wouldn't mind that either...
                • maxmekker
                  • 466
                  so if I were to fix up the surge crusher with a typhoon 500 ore another cheap
                  500 type 1500+ kv HK motor to run on 3s/4s for my boy's ,one of thise would be a ok choice ?
                  Drammen rock City
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3784
                    The problem with the Suppo ESC is heat dissipation. If using the throttle often, it will generate more heat. Increasing the problem.
                    If I were building something for a youth, I would use a more commercial quality ESC with warranty.
                    Chances are it would work OK for your application.
                    • Alexgar
                      • Aug 2009
                      • 3701
                      after maybe 10 runs mine finally burned up at about 100 amps i pulled the shrink and quite a few fets wernt in contact with the cooler
