Would you still race?
This topic is closed.
  • Diegoboy
    • Mar 2007
    • 7444
    Would you still race with a group that set down and enforced the following rule?
    In the spirit of good sportsmanship, any FE boats having a noticeable speed advantage over the faster nitro boats will be asked to detune their boats to ensure competitive racing. If they do not comply, they shall be disqualified from the class for the race weekend.
    62
    Yes
    0%
    32
    No
    0%
    19
    Maybe, but I may be discouraged
    0%
    11
    • 9481
    good poll!
    • LarrysDrifter
      Big Booty Daddy
      • 3416
      I would be happy to de tune.Competition is what makes racing fun.
      • Diegoboy
        • Mar 2007
        • 7444
        how far? swap to a lesser motor? change from a 42mm prop to a 32mm? There is no defination for the "de tune"
        Look at it from 2 sides:
        Spec class - You are already told what power plant you cannot use, if you're still faster, de-tune?
        Open class - Anything goes, but if you're still faster, de-tune?
        Have a closer look at the starement carefully
        If they're faster, why do we need to de-tune? It's clearly a biased rule
          • 9481
          sounds like the nitro guys are starting to cry
          maybe they need to learn to mod their motors to keep up!
          • boogaloo_d
            • Aug 2009
            • 42
            I would continue to race. I wouldn't be thrilled about it but I would still race. What happens if the nitro boat get faster?
            • Diegoboy
              • Mar 2007
              • 7444
              Absolutely nothing
              • ron1950
                • 3082
                sounds like a gas boat club rule
                • JMSCARD
                  • Mar 2010
                  • 4174
                  I wouldn't race if it was like that for "open" class... doesn't open class mean that you are allowed to use as much power as you can keep under control and on the water? That rule would be just wrong...
                  In spec class I would be totally fine with it....
                  • Darin Jordan
                    • 9446
                    Ditto... FE has such a HUGE advantage in many areas... it's really tough to put them on par... It's much easier for us to detune, prop down... etc...
                    Darin E. Jordan - Renton, WA
                    • Scott T
                      • 625
                      The wording to me reads that if you're noticeably faster than the "faster of the nitro boats" then you'll need to adjust. I would be fine if my boats were no faster then the fastest nitro boats (in that class), because a well sorted electric will likely finish more heats, and get more points.
                      Scott Tapsall
                      Pine Rivers Model Powerboat Club - Facebook Page
                      My Gallery
                        • 9481
                        what about setting your radio to 85% throttle like mine can do and on the last lap crank the radio to 100% and kick
                        • JMSCARD
                          • Mar 2010
                          • 4174
                          ESC killer...... 85% throttle for a long time equals sad caps...
                            • 9481
                            what if you add more caps?
                            • JMSCARD
                              • Mar 2010
                              • 4174
                              You will be putting a hurting on more caps..... :) there are many threads and posts on this.... do a quick search it will explain in great detail....
