Opinions between the Tenshock Minicat & Hor Micro Bolt hydros
  • martin
    • 2881
    What are opinions on either of these micro hydros from those that have used either or both boats. I live in the UK so will be potentially buying from their. Martin.
  • SweetAccord
    Speed Passion
    • 1322
    Greetings,
    The Tenshock are nicer in regards to the motor coupler and the wire drive. I have seen the HOR hydro and the wired drive is bigger and the coupler is awkwardly larger. Not sure why except for durability but the Tenshocks design are perfectly at the design they are at, anything larger is not needed even when upping the KV on the motors. The HOR does have a thicker motor mount. Hull wise for quality both are equal except that the HOR hydro cowl has two metal wires added into the front and back to help reduce the bend on the hatch cover, nice idea!
    Hope that helps.
